Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-19-2012, 09:42 AM   #1
Snow load
What would the snow load be on a hip roof 10x12 with a 6/12 pitch 24 inches on center
GILYBOY is offline   Reply With Quote
Old 04-19-2012, 10:20 AM   #2
Snow load
i FORGOT THE NRAFTERS WOULD BE 2X6
Old 04-19-2012, 10:22 AM   #3
Civil Engineer
Snow load
You forgot to mention where you are located. The snow load in New Orleans is zero. Typically snow load is shown in your building code, you should start there.
Old 04-19-2012, 02:19 PM   #4
Snow load
I asked a question this morning then had to leave.i asked the question wrong so will try again.
I live in hesperus colorado. The snow load requirement where i live is 65 lbs psf. I want to build a gazebo roof 10x12 hip using 2x6 rafters
spaced 24 inches on center with a 6/12 roof pitch . Will it meet the 65 pound psf requirement?
Are you ready for SNOW & ICE ? Roofmaster417 Roofing 15 10-09-2011 10:25 AM
Beware of Inappropriate Load Calculation Software - Source ACCA.org JJboy HVAC 5 09-06-2011 07:25 PM
quick snow load question organick Roofing 1 08-30-2011 04:59 PM
More Accurate Load Calculation zootjeff HVAC 9 12-14-2009 01:06 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
