Smoking Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-15-2011, 05:00 PM   #1
Smoking Chimney
I know this is more of a chimney problem but it could be my roof too. Whenever I light my chimney, it gets really smokey in my house! With the holidays coming, I'd really like to light my chimney for when everyone gets together at the house. Does anybody know what the problem is? We had a new roof put on last summer so I don't think that's the problem
BruceK24 is offline   Reply With Quote
Old 12-15-2011, 05:05 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Either your damper isn't opened or you need a chimney sweep, if it's a wood burner.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 05:51 PM   #3
It might be an inadequate flow problem
Hi,
There are a couple things that might be the cause of your chimney problems. It seems like your chimney doesn't have adequate flow. Your flow capacity is determined by the size of your connector, the flue, other passageways in the system and the amount of resistance offered by obstacles such as dampers or heat reclaimers, bends or buildup of creosote in the system. When was the last time that a chimney cleaning professional removed the creosote from your chimney?
Other factors which could reduce flow include: air leaks in a chimney; or venting multiple appliances into a single flue. Is your kitchen hood venting into your chimney flue?
It's impossible for me to determine what the cause of your problems may be without looking at your chimney. You should have a CSIA certified chimney professional look into it.
Clayton Brink
American Fireplace
www.americanchimneyservices.com
Am.Fireplace is offline   Reply With Quote
The Following User Says Thank You to Am.Fireplace For This Useful Post:
Roofmaster417 (12-16-2011)
Old 12-16-2011, 06:07 AM   #4
DIY staff
Rewards Points: 7,174
Has the chimney ever worked properly--or is this a new situation?
Do you have forced air heating?
Have you tried lighting the fire place with a window open?
More clues,please.
Old 12-16-2011, 11:45 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
We have a wood burning insert. This works for us if we have trouble getting it to draw.
Tags
chimney , smoking
Capping my chimney sbmfj General DIY Discussions 9 10-29-2011 10:45 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 06:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 07:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
