-   -   Smoking Chimney (http://www.diychatroom.com/f9/smoking-chimney-126721/)
BruceK24 12-15-2011 05:00 PM
Smoking Chimney
I know this is more of a chimney problem but it could be my roof too. Whenever I light my chimney, it gets really smokey in my house! With the holidays coming, I'd really like to light my chimney for when everyone gets together at the house. Does anybody know what the problem is? We had a new roof put on last summer so I don't think that's the problem
titanoman 12-15-2011 05:05 PM
Either your damper isn't opened or you need a chimney sweep, if it's a wood burner.
Sent from a Samsung Galaxy S2
Am.Fireplace 12-15-2011 05:51 PM
It might be an inadequate flow problem
Hi,
There are a couple things that might be the cause of your chimney problems. It seems like your chimney doesn't have adequate flow. Your flow capacity is determined by the size of your connector, the flue, other passageways in the system and the amount of resistance offered by obstacles such as dampers or heat reclaimers, bends or buildup of creosote in the system. When was the last time that a chimney cleaning professional removed the creosote from your chimney?
Other factors which could reduce flow include: air leaks in a chimney; or venting multiple appliances into a single flue. Is your kitchen hood venting into your chimney flue?
It's impossible for me to determine what the cause of your problems may be without looking at your chimney. You should have a CSIA certified chimney professional look into it.
Clayton Brink
American Fireplace
www.americanchimneyservices.com
oh'mike 12-16-2011 06:07 AM
Has the chimney ever worked properly--or is this a new situation?
Do you have forced air heating?
Have you tried lighting the fire place with a window open?
More clues,please.
Blondesense 12-16-2011 11:45 AM
We have a wood burning insert. This works for us if we have trouble getting it to draw.
