SmartVent Versus TheEdgevent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-18-2011, 09:59 PM   #1
SmartVent versus TheEdgevent
I sat down tonight with a prospective roofing contractor to discuss my project and according to my wife "argued" with him in a friendly manner on how the Smart Vent would be a better solution, because of what I have read on this forum, than The Edge Vent, which he has used. He was unfamiliar with the Smart Vent but felt that it was the same as The Edge Vent since both draw in intake air at the edge of the roof by the gutter. After reviewing their online brochures, they both look like they bring in air at the same points. What am I missing? Thanks
Columbus is offline   Reply With Quote
Old 03-18-2011, 10:08 PM   #2
Rewards Points: 1,088
I can't say which is better without having both products in my hands, but if you live in a cold weather climate area, be aware of possible issues with ice damning.
handy man88 is offline   Reply With Quote
Old 03-18-2011, 10:21 PM   #3
Thanks, while I don't live in the harshest areas of the country, I did have a leak and an ice dam issue in central Ohio last year. That is one of the reasons I am looking to improve my attic ventilation with this new roof project.
Old 03-18-2011, 11:01 PM   #4
I think you're going to get ice damming issues even if you improve your attic ventilation. The reason is from the freeze-thaw cycle from sunlight when the temperature is hovering around freezing, which has little to do with attic ventilation.
The only way I think you can eliminate this is to add heating cables around those edge vents.
Old 03-19-2011, 09:21 AM   #5
old timer
Because there is still the possibility of ice dams even after your best efforts to ventilate the attic, you might want to look into the vents that install behind the gutter. Such as the DCI fascia vent.
dmc@RCR is offline   Reply With Quote
Old 03-19-2011, 09:47 AM   #6
The promotion of continuous intake ventilation, along with the installation of a properly functioning exhaust vent system, will lower the temperature of the attic air and thereby, the underside of the roof deck sheathing.
This eliminates the "Hot Spots" which melts the snow pack from the underside.
I have successfully been installing the Smart Vent for continuous eave edge intake ventilation since 2001, with no reported adverse affects. I also have done follow up studies after substantial snow-falls, visually observing the reduction of melting snow and with no evidence of even the potential for ice-dams beginning to occur.
The Edge intake Vent from Airvent is similar to the Smart Vent, but is thicker and has the slot cut-out 1 inch lower on the roof decking than the Smart Vent.
Functionally, they both should work the same, but I choose to stick with what has a decade long proven track record for me.
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-21-2011, 09:15 PM   #7
Thanks everyone for the information. The way my attic is insulated the extra inch with the Smart Vent would help. I also like the lower profile. As you can see from the picture I have no overhang and I am currently venting the attic with 2 gable vents, 2 roof line vents and a wind turbine. And while I have not had any moisture issues I just don't feel like I am getting a good air exchange up there currently and want to improve this with the new roof.
Old 03-22-2011, 04:31 AM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I also prefer the fascia vent when there are gutters in the equation.
seeyou is offline   Reply With Quote
Old 03-22-2011, 03:14 PM   #9
Is it possible to install "turtle vents" on the flat side of the house kind of like gable vents, but lower along the floor of the attic to work as intake/soffits?
Old 03-23-2011, 08:35 AM   #10
old timer
I think that would be possible but might look a bit odd.
Why not some vents designed for walls. I've bought some nice vents from this site http://www.copperlab.com/ .
Old 03-23-2011, 09:51 PM   #11
Thanks everyone for the input If I install the Smart Vent my contractor says I need to install some insulation baffles, which makes sense. I am thinking of just stapling some thin material across the roof joists from the edge of the roof up towards the peak. My question would be how high I should go? If the Smart Vent cuts in at 6 inches would 12 inches above that work to ventilate the attic space? 18 inches up from the roof line would be very clear of any insulation. Thanks.
Old 03-23-2011, 10:49 PM   #12
As long as it clears the current insulation height and anticipated height in the future, then you're fine.
Old 03-24-2011, 05:29 AM   #13
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
The insulation will probably need to go between the rafters (roof joists) to get the desired thickness. What you propose would leave a "cold" strip.
Old 03-24-2011, 03:51 PM   #14
Somebody who wants to start a business can use my idea and create "siding vents" which act like edge vents but will be used under siding instead.
Old 03-24-2011, 03:54 PM   #15
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
http://www.cor-a-vent.com/siding-vent-sv-3.cfm
replacing smartvent hard at work Roofing/Siding 3 02-17-2013 04:12 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Ductless versus Central Air Upgrade ??? wrldruler HVAC 9 09-25-2008 01:05 PM
SmartVent RochesterBruce Roofing/Siding 3 03-17-2008 06:33 PM
