Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-01-2011, 06:40 PM   #1
SmartVent with ice dams and mold
Mid Roof Smart Vent and ice dams
I had SmartVents installled on my roof last year. I also have a Cobra Ridge vent, two 30" gable vents, as well as soffit vent baffles to allow my old soffit vent to breath. I installed a whole house fan with a temperature gauge to help during the summer. The very first storm we had with accumulative snow and rain I ended up with an ice dam on the back side of the roof (north facing). The ice/water went thru the SmartVents and soaked my sheathing. I now have a major mold problem. The contractor is saying the products aren't defective and that they installed them properly. What happened? What should I do next?
rlamik is offline   Reply With Quote
Old 05-02-2011, 08:02 PM   #2
Super Moderator
Did they install Ice and Water Shield over the Smart Vents?
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 05-02-2011, 10:40 PM   #3
Do you have more than adequate attic insulation?
handy man88 is offline   Reply With Quote
Old 05-03-2011, 06:37 AM   #4
Ed- After reading all your posts, that's what I'm thinking, my contractor didn't cover the vents with the ice and water shield. Is there an easy way to check this?
Although we don't have two feet of insulation in the attic, it's adaquate. We installed it a few years back. And there's no gaps around lighting fixtures and we were careful not to block the old soffit vents and put in the baffles to ensure ait flow.
Only other thing to mention is that the front of the house faces almost direct south and the back side faces north. And that it is a small two story house- 24 by 24 that you can only stand in the middle of the attic.
-thanks
Old 05-03-2011, 06:02 PM   #5
Super Moderator
-thanks
Lift up the bottom course of shingles along with the starter shingles and see if any product is installed On Top of the Smart Vent.
See if it is adhered to the top surface of the vent material, or just nailed/stapled in place, such as the case would be if it were only some version of felt paper.
Ed
Old 05-04-2011, 06:34 PM   #6
old timer
You misunderstood Ed. The ice and water will be below/under and also on top of the vent. Leaving the vent open. You can't close off the vent or there is no air flow.
It's not a good idea to put a hole in the roof right where there may be a possibility of ice dams and pools of water. It would have been better to install better soffit or below/behind the gutter vents.
dmc@RCR is offline   Reply With Quote
Old 05-30-2011, 03:40 AM   #7
The best thing for you to do is to hire a professional and let them remove the mold and ask them about what could be the problem that caused your vent to mold or perhaps what could be the problem on your roof.
packet04 is offline   Reply With Quote
Old 02-12-2012, 01:33 PM   #8
Ed-
My original contractor never replied to my requests. After the freak October snow storm where we got 14" of snow my sheathing was wet again. I finally got another contractor over the house to remove the Smartvent in December. We took pictures to confirm the vent was not installed properly. Could you concur this is where the mold orignated from?
-thanks
Old 02-12-2012, 01:40 PM   #9
I dislike your venting system for precisely the reasons you have had. To me it would have been better to not have the vents at all than have the possibility of water intrusion.
Second the mold problem may not be that bad, may just be discoloration from having the water back up through the vents.
Now as far as the ice damns are concerned you are getting too much hot air from inside escaping. that means you need to just pack a lot more insulation creating a hot roof than what you have.
I live in the NE where we get these ice damning situations and on my house I packed it and we still get the damns, a lot less than before but we still get them.
framer52 is offline   Reply With Quote
Old 02-12-2012, 03:44 PM   #10
MJW
I've never done a hot roof/cold roof yet, but I was under the assumption that they use closed cell foam insulation, and a dehumidifier or air exchanger inside.
MJW is offline   Reply With Quote
Old 02-12-2012, 03:47 PM   #11
Hot roof means any roof with no ventilation.
The Following User Says Thank You to framer52 For This Useful Post:
concretemasonry (02-12-2012)
Old 02-12-2012, 06:13 PM   #12
ParagonEx's Avatar
It looks like it was installed right. Didn't I&W though.
ParagonEx is offline   Reply With Quote
Old 02-12-2012, 08:42 PM   #13
old timer
The vent was installed ok. It just does not work(as you have noticed with the ice damming). You've got 5/8" opening covered by a fabric filter. Not much air flowing there.
Add 4-5 inches of snow covering it and it won't work at all.
The ice and water shield might have prevented water backing up under the shingles and into the hole in the roof, but it won't stop the water from backing up from the gutter, through and under the plastic vent, and into the hole in the roof.
Air seal the ceiling so no interior air is getting into the attic.
Remove the smart vent and close the slot in the decking.
Install ice and water shield to the decking.http://www.roofingcontractorreview.c...ice-guard.html
Install soffit, or fascia vents under and behind the gutter.
Replace the Cobra Ridge vent with a better product. (gaf airvent 11 or similar)
Old 02-12-2012, 09:49 PM   #14
Exterior Construction
Windows on Wash's Avatar
+1
Seen more than a few roofs backed up from Cobra vent and Smart vent is okay but not ideal in most cases.
Old 02-12-2012, 10:45 PM   #15
MJW
Only if it's sealed, correct? Fiberglass is not ideal to pack an attic completely with. Just look at our walls with fiberglass. They need fully sealed poly to keep the moisture away from it.
I've seen buildings with insulation and no ventilation. The sheathing rots from within because of all the heat and moisture getting up there. No different than a wall with no poly or air sealing.
Wet Insulation due to iIce dams colleen7560 Insulation 5 04-16-2011 01:02 AM
molding ceiling duckieduck General Discussion 5 03-08-2010 02:52 PM
Frost in the Attic 295yards General Discussion 13 12-07-2009 05:27 PM
