Smart Vent Vs. Inhaler Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-19-2008, 11:49 AM   #1
Smart vent vs. Inhaler vent
Im down to my final decision on my re-roof. I live in Cleveland and get ice dams. My house is a modern, shed style with no eaves. My concern with Smart vent is clogging from ice dams or pine needles. My concern with inhaler vent is durability and its lower in th attic air intake from the fascia may clog with insulation. Im leaning toward the smart vent, ive read some of the posts here already, Ed the Roofer's posts make alot of sense to me.
teletodd is offline   Reply With Quote
Old 09-19-2008, 12:17 PM   #2
Unfortunately, I can not comment on the Inhaler Vent for you.
Fortunately for you, I am an individual who does not recommend a product without substantial in field testing, or would at least advise of the foreseeable pitfalls if I knew of any.
I started using the Smart Vent by DCI Products around 6 years ago and I have learned that when you find a product that works and performs as stated and meets all of your criteria expected, don't change.
I recently posted this link in another thread, which addresses the concerns regarding Ice Damming and Clogging at the Intake portion of the Balanced Ventilation Solution.
http://www.contractortalk.com/showth...ighlight=vents
Note, you can click on those photos to enlarge them and you can clearly see the grayish fabric filter material remaining unobstructed and you can see the results of the flowage of air through the top Shingle Vent II Ridge Vents, which obviously provides evidence of proper air movement and exhaust.
Ed
Ed the Roofer is offline   Reply With Quote
Old 09-19-2008, 02:49 PM   #3
smart vent as fascia vent
Is there any advantage/disadvantage of vent placement? ie fascia vent vs. above the gutter where the smart vent goes? The issue with the fascia vent might be that its so low on the roof line that insulation might spill over it? but by venting at a lower point of the roof (fascia) would it be more efficient causing more air to circulate upward and out the ridge?
Old 09-19-2008, 07:09 PM   #4
I would be conserned about insulation blockage more from a fascia vent, but if the precautions were taken and applied correctly, it would potentially work better, but I am not going to mess with a proven result, depicted in the photos of no ice damming on the houses I used it on.
Ed
Old 09-19-2008, 09:36 PM   #5
Ive decided to go with smart vent. Thanks for the help.
Old 09-20-2008, 09:12 PM   #6
Smart vent and gutters and snow
The gutters n my house will be hung on the facia just below the smart vent, what is to stop snow or ice from blocking the air intake? Will they still function?
Old 09-20-2008, 11:09 PM   #7
The houses I posted photos of in that link I provided had gutters on them.
A gutter, by design, especially the newer styles, has a slightly lower fron edge, which will theoretically allow the frozen mass rize over the lip and then begin the melting process on the front side of the gutter.
Even take a look at the old 1/2 Round styles during the winter. The icicles eminate from the front side, not the rear and they are a free hanging gutter, suspended only by the strap and T-Lock bar.
I drove past the 1st house every single day on my way to and from dropping my kid off at pre-school and made a mental note of each and every possibility that needed to be explored throughout the entire winter.
It was a daily observation with no ice formed barriers precluding the Smart Vent from performing as stated. Also, the continuous heat exhaust from the Shingle Vent II Ridge Vent further enhanced the diagnosis of a properly working system, since this was installed on a cathedral/vaulted ceiling on that home.
Ed
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 01:01 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
