Small Hole In Copper Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-16-2007, 11:29 AM   #1
Question
Small Hole in copper roof
I have a very small hole in a copper roof above a bay window.
Size approx: 1/2-3/4" long by 1/4" wide
Is this something that can be repaired via a "filler" or patch?
Thanks for your insight.
Chris
vabrave is offline   Reply With Quote
Old 05-16-2007, 06:41 PM   #2
Rewards Points: 5,336
Copper patch soldered on top.
Ron
Old 05-16-2007, 07:40 PM   #3
Agreed.
But, if you want all of the pans on the bay window to look equally symetrical, if the hole is centered, sort of, then do a similar patch on each of the other pans, just to make it looks like it was intended to be their in the first place.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-16-2007, 07:55 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Yep, or go over the entire panel/section so you can hide the seam at the edges.
Brik is offline   Reply With Quote
Old 05-20-2007, 05:24 PM   #5
Rewards Points: 150
A small hole would only need a touch of solder.
RooferJim
RooferJim is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
zinc or copper roof mildew protection shimp Roofing/Siding 2 04-30-2007 09:52 PM
Copper roof Burat Roofing/Siding 1 04-08-2007 09:51 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
How to roof a small shed???? Sellncars Roofing/Siding 2 09-23-2006 12:21 AM
