-   -   Small Hole in copper roof (http://www.diychatroom.com/f9/small-hole-copper-roof-8498/)
vabrave 05-16-2007 10:29 AM
I have a very small hole in a copper roof above a bay window.
Size approx: 1/2-3/4" long by 1/4" wide
Is this something that can be repaired via a "filler" or patch?
Thanks for your insight.
Chris
Ron6519 05-16-2007 05:41 PM
Copper patch soldered on top.
Ron
Ed the Roofer 05-16-2007 06:40 PM
Agreed.
But, if you want all of the pans on the bay window to look equally symetrical, if the hole is centered, sort of, then do a similar patch on each of the other pans, just to make it looks like it was intended to be their in the first place.
Ed
Brik 05-16-2007 06:55 PM
Yep, or go over the entire panel/section so you can hide the seam at the edges.
RooferJim 05-20-2007 04:24 PM
A small hole would only need a touch of solder.
RooferJim
