Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-21-2011, 09:58 PM   #1
Is this sloppy work or am I too picky?
There was a roof leak near the chimney. Hired a roofer to locate the leak and fix. They broke a bunch of tiles when they were trying to find the leak.
When it's done, this is the result.
To me it seem a bit sloopy. I know the color will not match because mine is 5 years old and color faded. However, because they reused some old tiled that were not completely broken, and didn't clean off the concrete blobs on the edges of those, when they put it back, they do not hug tightly to the old tiles, some tilt up a bit, some down a bit. You can see it on the first row from the chimney, the third pic.
While they fixed my tiles, as they walked around, they also broke about a dozen tiles. Is that something they should fix or that's something I need to fix (as there is no proof that they broke it) but I know they were not like this when they started the project. Even the guy who came to estimate the job, broke two tiles before I hired them.
I just want to know, would you consider this a sloopy job, or acceptable?
Question, if I want to fix the piece on the valley myself, and need to cut that triangular shape, can I use a 4.5" grinder with a diamond blade?
miamicuse is offline   Reply With Quote
Old 12-21-2011, 10:56 PM   #2
You might be too picky about the color not matching like you said yours are a few years old but if they broke tiles they should fix them.
msaeger is offline   Reply With Quote
Old 12-21-2011, 11:16 PM   #3
Tileguy
Bud Cline's Avatar
Is this sloopy work or am I too picky
No no you are correct, color mismatch aside they absolutely did sloppy work. If they also broke those tiles they should be coming back to fix their sloppy-ness.
Have they been paid in full?
Old 12-22-2011, 12:48 PM   #4
Low Slope Roofing
yeah they fix the tiles, color match is beyond their control. Yes a angle grinder will cut them.
1985gt is offline   Reply With Quote
Old 12-22-2011, 02:15 PM   #5
Looks a mess to me. I would have expected lead flashings dressed into the profile of those double romans.
stuart45 is offline   Reply With Quote
Old 12-22-2011, 02:26 PM   #6
Tileguy
Bud Cline's Avatar
I see some helpful Moderator has corrected some spelling.
Takes all the fun out of it.
Old 12-22-2011, 02:28 PM   #7
Architectural Designer
AGWhitehouse's Avatar
I'm not even a roofer and I know you're not supposed to walk on those...you lay a ladder out and walk on that to distribute your weight among many tiles. Walking creates point loads on single tiles resulting in the broken tiles...hence your mess
With such a hack job being considered "finished" good luck getting him to fix it. I, personally, would hold payment until he decides whether he's going to fix it or walk away. If he fixes it, great. If not, use what would have been his money to hire a competent roofer to fix it.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
grounding the workpiece you're welding jarnold Electrical 41 09-08-2010 08:33 AM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 12:53 PM
Need help with permit/city got a Stop Work Order. amdspitfire General Discussion 39 02-07-2008 03:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
