Slopped Shed Roofing Material - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-17-2014, 01:46 PM   #1
Slopped shed roofing material
I have a 5 foot x 6 foot shed with 15 degree slope. I used 3/4 plywood then 30 lb felt and aluminum drip edge. Whats a good long lasting material to put over 30 lb felt? Thanks
ddadda is offline   Reply With Quote
Old 03-17-2014, 01:47 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 596
Ayuh,.... Steel,....
Bondo is online now   Reply With Quote
Old 03-17-2014, 01:48 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Galvanized metal, or galvalume. Don't use aluminum unless the felt was installed with aluminum nails though.
tinner666 is offline   Reply With Quote
Old 03-17-2014, 02:01 PM   #4
Any type of roll roofing available?
Old 03-17-2014, 02:37 PM   #5
Pro Slate Roofer
tinner666's Avatar
Not that I ever heard of. There is a prodcut called roll roofing that goes on without felt and is good for a year or two, but my only experiences with it is removing and replacing it, and often the decking, with roof materials, either metal, or shingles.
Old 03-18-2014, 12:29 PM   #6
Low Slope Roofing
Rewards Points: 114
There is the self adhered modified I guess you could call them rolled roofing, but rolled roofing to us is the 90# junk that lasts two years like Tinner said. I think you can do the self adhered over normal felt but you would have to research that. I know they make a nail able base sheet and a self adhered base sheet, we have used both, never just over felt though.
1985gt is offline   Reply With Quote
Old 03-18-2014, 08:48 PM   #7
Doing This Way Too Long
Rewards Points: 532
nailed base, self-adhered mid-ply (optional), then self-adhered capsheet. DIY friendly
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
Old 03-19-2014, 12:33 PM   #8
Low Slope Roofing
Rewards Points: 114
Right, but I don't know for sure that you could use felt. We've always used what ever manufactures nail base. I guess you could alway nail that base sheet over the felt and then the self adhered cap. Be a good roof for a shed!
Old 03-19-2014, 10:15 PM   #9
Rewards Points: 532
I agree. The base wouldn't know if you were nailing over felt or bare plywood. Just make sure you use the base to adhere to.
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
shed roofing questions amakarevic Building & Construction 10 02-09-2011 09:17 AM
siding a shed before roofing amakarevic Carpentry 5 01-30-2011 09:10 PM
Rudimentary Shed Roofing Question CGofMP Roofing/Siding 11 03-31-2006 10:24 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
