Sloped Roof Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-27-2010, 03:59 PM   #1
imtryingtofixit
sloped roof insulation
This is my 1st post so hope I'm in correct place. I live in sunny Alberta, Canada and own a 1915 two storey house. It is built on the idea of a barn style with an approximate 2 foot flat area at peak, then roof gradually slopes down - east, west - to meet walls. 9' ceilings on second floor. no soffits, so no soffit vents. The sloped roof is the ceiling of the bedrooms with of course the 2x4 construction gap. All inside walls, ceilings are tongue and groove shiplap? wood. Very solidly built. How do I go about insulating the "ceilings" in the bedrooms and still leave the air gab? No room for vapour barrier or the rafter air barriers that they now have. As no air enters through soffet vents now to keep roof cool will I be creating a worse situation if I have blown insulation put in these areas. Will be reroofing this spring and do not have sheeting on roof either. Should I have insulation blown in this way. Should sheeting be installed. Will be using water and ice shield on bottom portion and valleys. Should this be only place I install this. Floor in attic (undeveloped) is well insulated with blown insulation 18". Do I need roof ridge venting. Should I install whirly bird vents. Thanks for any assistance you can offer.
imtryingtofixit is offline   Reply With Quote
Old 03-03-2010, 12:51 PM   #2
Are you going to be doing the roofing job yourself? Either way I would have a few roofers bid the job. Find out how they would handle your issues. It will tell you much, both about the roof and about the roofers.
I'd like to offer advice, but, without pictures or drawings, your explanation is not sufficient.
jeweler is offline   Reply With Quote
The Following User Says Thank You to jeweler For This Useful Post:
imtryingtofixit (03-04-2010)
Old 03-03-2010, 09:58 PM   #3
jlhaslip's Avatar
Rewards Points: 2,188
I don't think blown-in insulation works on a sloped ceiling space, but I might be wrong.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Old 03-04-2010, 11:45 AM   #4
imtryingtofixit
Thanks for the great ideas. This should be a good way to determine a good contractor. I am also adding photos. Sorry about that.
Old 03-04-2010, 12:51 PM   #5
Registered User
Rewards Points: 5,516
As jlhaslip said: http://www.energy.wsu.edu/documents/...r_04-2006A.pdf
Check with your LOCAL Building Department.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 03-04-2010, 02:07 PM   #6
Commercial Roofing
AaronB's Avatar
If your conditioned living space is well insulated, you shuld be good to go. You should not need insulation in the roof framing unless youre trying to convert this space to conditioned space.
Ventilate it.
Install roof sheathing if youre installing a roofing system that needs it.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-04-2010, 05:49 PM   #7
imtryingtofixit
I am not sure that I understand your advice. Or maybe its that my explanation was not clear. As noted in the photos which I have just downloaded the sloped roof is the ceiling in the bedrooms - 4 bedrooms. The roof is constructed of 2X4's, horizontal boards instead of sheeting, asphalt shingles. In some areas the boards leave numerous inches between each meaning that the shingles are the only thing between attic and the great outdoors. There is a open air vent on each gable end which is the only venting. Please refer to 1st quote for concerns. Thanks again for all of your help.
Old 03-04-2010, 08:55 PM   #8
jlhaslip's Avatar
Code in Alberta is R40 (or R42) for ceilings and there is no way you will be getting that out of a 2x4 construction for the roof unless there is something new on the market. Pink rigid styrofoam is around R5 to the inch, so that gives you about R20 only.
You should look at adding a cold roof system to your roof to get a decent insulation value.
Strip the roof and add a 2 x 8 rafter system on top which will allow you to improve the insulation to near code and have the ventilation you require.
More money, but money well spent.
Old 03-05-2010, 02:46 AM   #9
Commercial Roofing
AaronB's Avatar
My mistake.
I would add as much insulation as possible when you redo the roof. To get the maximum R value, I would definitely use closed cell polyurethane foam.
Old 03-05-2010, 05:48 PM   #10
First thing is check with the building department to see if a permit is required, and what minimum code standards you will need to meet. You need to confirm the true size of your rafters. I doubt they are only 2x4. Once you know what is there then you can talk to the building department about how you need to rebuild your roof. They will also address the issue of a cold roof or other methods of proper ventilation. Then you can weigh the options of different kinds and amounts of insulation. Based on your explanation this is clearly a job for a contractor. Just be sure they explain exactly how they are going to build your roof and list the components they will use. You will be without any roof for the period between tearing off what you have and when they start the new one. Have them explain how you will be protected during this time. And, be sure they tell you how long...
Old 04-01-2010, 07:52 PM   #11
imtryingtofixit
thanks for the help. good advice.
Tags
insulation , roofing
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Radiant Barrier + Insulation with Metal Roof customfab Building & Construction 8 02-16-2010 09:47 PM
Wet Roof Insulation supton Roofing/Siding 3 11-28-2008 04:12 PM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 12:45 PM
