Slate Roof Trim. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-24-2011, 04:30 PM   #1
Slate roof trim.
Hello: Have a pitched slate roof where the slates stop at the outside edge of the 9" solid brick wall gable end. The slates at this point are finished with a strip of render about 12" wide and raised about 2" above the slate.
It seems a fairly typical way of finishing older style houses, at least here in the UK.
The render is falling away and, though it would not be impossible for me to chip it all off and replace with new mortar I'm wondering if there's a more modern way of doing it. Perhaps a lighter weight material that will save me hauling umpteen buckets of mortar up there.
Am not averse to hard work but am not young either.
PedrX is offline   Reply With Quote
Old 08-24-2011, 04:59 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture if you can.
We have a member from the U.K. with slate experience --when he checks in I hope he spots this.
Plenty of good roofers on this side of the Atlantic,too.---Mike---
Old 08-24-2011, 05:03 PM   #3
Will do, Mike. Thanks.
Old 08-25-2011, 12:32 PM   #4
Rewards Points: 582
There are some dry verge systems for slate roofs now, although you might break a few slates getting the render off.
That method of rendering was popular where there was a problem with the wind taking off the end slates.
There is another method popular in North Wales using angled ridge tiles bedded over the verge.
stuart45 is offline   Reply With Quote
The Following 2 Users Say Thank You to stuart45 For This Useful Post:
oh'mike (08-25-2011), PedrX (08-25-2011)
Old 08-25-2011, 05:52 PM   #5
Thanks, Stuart. Have spent an hour trying to post a photo without success.
Have looked at the the dry verge systems and now wonder if it wouldn't be easier/cheaper to replace the existing render particularly taking into account the following. (What exactly are these angled ridge tiles by the way?)
It occurs to me that I'll have to render the whole gable end anyway. The water is obviously getting behind the render. So, if you agree it's ok to redo the verge again in mortar, presumably the wall should be done first, then a batten fixed to the finsihed wall to get a bit of an overhang on the verge mortar.
Another thing that struck me is: should I strip all the roof slates off and put a membrane underneath? The roof timbers and battens are sound, slates ok, but there may be nail fatigue after (50?) years. Even the lime mortar plastered under the slates is still reasonable but... well, I'll be putting a lot of effort into the interior - hand made fitted furniture and stuff - and it worries me, if a slate blows off...
The epdm rubber is on the new extension roof. Just waiting for a dry day to stick it down. Never did get an answer to my previous post ( what do you stick rubber to bitumen - tar - pitch - whatever you people call it). The epdm supplier says use impact/contact adhesive - as reccomended for the decking but... often the manufacturer/supplier knows less than the user.
Thanks for your interest so far. Will get some help with the photo from someone with a better understanding of this infernal electronic gadget.
Old 08-26-2011, 03:18 PM   #6
Rewards Points: 582
These
Make sure you use sharp sand/cement for over the verge.
Difficult to say without seeing the roof. If you are doing all the work yourself and reusing most of the slates it shouldn't be too expensive.
I would use a breather membrane under the slates. The scaffold would be the biggest expense.
Hope you can get some photo's on soon PedreX.
Old 08-26-2011, 05:03 PM   #7
Thanks, Stuart. Will study your advice. In the meantime I think I've managed the photo by reducing the pixel size.
Old 08-27-2011, 03:56 AM   #8
Rewards Points: 582
See what you mean about the render. Looks like you need some work on the stack as well. The slates look to be in good nick though, as they are probably good quality Welsh. I'm buiding an extension at home and using 14x6 reclaimed Welsh on the roof.
Here's a shot of a house in North Wales with ridge tiles at the verge.
Old 08-27-2011, 02:17 PM   #9
The ridge tiled verge looks really neat. Will certainly consider this idea. Thanks.
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
slate roof replacement w36cowgirl Roofing/Siding 9 03-12-2010 01:35 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 07:25 PM
