Slate Roof Sealing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 07:20 PM   #1
Slate roof sealing
what is the best epoxy coating for slate pitched roofs
129tony is offline   Reply With Quote
Old 12-11-2011, 07:36 PM   #2
Rewards Points: 13,266
Slate roofs do not use a sealer. If it's leaking there's something wrong.
Old 12-12-2011, 01:25 AM   #3
Doing This Way Too Long
Rewards Points: 532
Oh I kinda shuttered just reading that question.
OldNBroken is offline   Reply With Quote
Old 12-12-2011, 07:41 AM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Putting any sealer on a slate roof raises the cost of any repairs exponentially.
Since slate are replaced and charged by the piece, one broken slate where the homeowner slaps some cement on the opening, will cause 5 to 7 slate to need to be replaced, not the one. Jobs that would cost $300.-$500. will often exceed $2,000.00 if the home owner decides to use cement or anything else, including coating in a DIY effort.
If you want to go the DIY route, buy a roll of .019 Black/Brown aluminum and cut slate sized pieces from it and and slip the pieces under and over the broken slate to make temporary repairs. Then, when a professional comes to make the permanent repairs, the cost will not increase.
Conversely, if you go ahead and put enough goop on the roof, a once permanent roof will need to be replaced, most likely with a shingle roof that will have to be replaced every 10-20 years.
And the cement/sealer, will fail right from the start.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Gymschu (12-12-2011)
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
slate roof replacement w36cowgirl Roofing/Siding 9 03-12-2010 02:35 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
