Skylights And Vents In Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2010, 02:23 PM   #1
skylights and vents in flat roof
Roof is a rolled out mod bitumen flat roof. I'm putting 3 solar tubes into it and have 2 plumbing vents that need to go through. I've done roll-out roofs and shingle roofs before. In those you just set the new flashing under the shingles or roll and tar the hell out of it. I've never worked with a flat roof and wanted to make sure that I'm doing the right things to ensure that the flashing for the skylights seals to the old roof. What products/techniques should I be using? Thanks in advance for the help.
Oh - and have a couple places where some previous owner screwed the satellite dish directly through the roof and then just laid down a bunch of silicon. Figure that I should probably fix that while I'm up there - especially since that sat. dish is no longer being used.
I'm assuming that I can just buy some peel and stick and patch but I wanted to make sure that it would adhere and see if there was anything I should be worried about.
brownmoose is offline   Reply With Quote
Old 05-15-2010, 10:49 AM   #2
Doing This Way Too Long
Rewards Points: 532
flash it then 3-course it.
OldNBroken is offline   Reply With Quote
Old 05-15-2010, 02:29 PM   #3
Commercial Roofing
AaronB's Avatar
you should build a curb for each solar tube. That is unless they have 'em designed for flat roofs now. if it is just the flange and dome, then a curb is definitely in order. Then flash the curb and make the flange work somehow. There are probably better skylights available for solar tubes.
__________________ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
flat roof skylights
Choosing flashing cement for flat roof stubits Roofing/Siding 19 08-26-2010 11:03 PM
need some advice on best roof ventilation for this house longshanks Roofing/Siding 9 07-26-2009 06:49 AM
Rubber Roof over Ice & Water Shield PerpetuallyRepairing Roofing/Siding 23 01-08-2009 10:50 PM
Roof Venting Issue, crawlspace supton Roofing/Siding 1 11-12-2008 06:44 AM
How to properly vent hip roof JTK Roofing/Siding 7 06-02-2008 04:38 PM
