Skylights And Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-29-2010, 11:56 AM   #1
Skylights and roofing
I want to have skylights installed, but my roof also needs replacing. Does it matter which I have done first? Thanks
mgalligan is offline   Reply With Quote
Old 06-29-2010, 12:16 PM   #2
I did mine at the same time
Replaced the roof & installed skylights
Ideally with the way the flashing ties in it should be at the same time
What kind of roof ?
The Following User Says Thank You to Scuba_Dave For This Useful Post:
mgalligan (06-29-2010)
Old 06-29-2010, 12:23 PM   #3
Thanks Dave
The roofing will be composite; the skylights will have curbs. There may be a considerable amount of time between the projects though, which is why I'm wondering.
Mike
Old 06-29-2010, 02:08 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
If you do the skylights first (no reason not to if it will be awhile before you re-roof), be aware that the flashing may need to be replaced when the re-roof is done.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Tags
replace roofing , skylights
Got all my roofing supplies on order. Missing anything? slickgt1 Roofing/Siding 8 05-18-2010 05:23 PM
Roof cracking, 70 years worth of roofing, need suggestions slickgt1 Roofing/Siding 5 04-04-2010 12:10 PM
Replacing skylights... TJ198 Roofing/Siding 11 12-11-2009 10:27 AM
Flat Roof Repair--Question on roofing type buncoroad Roofing/Siding 2 10-18-2009 08:35 PM
Are roof skylights leaking? Halron Roofing/Siding 3 04-15-2007 03:06 PM
