Skylights Replacement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-26-2012, 01:44 PM   #1
Rewards Points: 27
Skylights replacement
Hello everyone!
My house was build in 1987,and it still has original skylights. Its time to replace them, since one of them are leaking in. So far I only had one estimate: replace two skylights 22"x46", wasco deck mount type for $1640. Is it normal price or not? I believe our skylights are curb mount, so they gonna need to cut some drywall for deck mount skylight? What also do I need to know before I'll hire someone? Looking for comments and advice.
Thanks!
Mikhail is offline   Reply With Quote
Old 04-26-2012, 01:48 PM   #2
the Musigician
DangerMouse's Avatar
Too many variables.
see here---> "How much will it cost?" Asking for price estimates here.
DM
Old 04-26-2012, 01:51 PM   #3
Rewards Points: 13,270
Hello everyone!
Thanks!
As far as pricing no one here is going to be able to help with that one on this site.
Why not find out why and where it's leaking instead of replacing. Could be as simple as fixing the flashing.
Curb mount just means the light sits up higher off the roof and really has nothing to do with the inside.
Unless you change the size there should be no need to cut the drywall.
Old 04-26-2012, 06:07 PM   #4
Metal Roofing
Rewards Points: 600
2246 velux flat glass curb mount from HD or Lowes are $207 and some change each out the door.
Leak solved if its just the skylights. If you have poor installation of the skylights in the roof, thats a completely different ball game. You would need to fix the roof issue then get new lids.
Pics would help
I dont know that brand of skylight you mentioned, are they operable..manual or electronic. Flat glass or Acrylic. Could mean the difference in price of $1000 vs plain curb mounts. We need more details.
Pics
AndyWRS is offline   Reply With Quote
Old 04-27-2012, 08:36 AM   #5
Rewards Points: 83
Considering you can get a decent Velux skylight for under $200, and they are only held on by 8 screws or less. $1640.......hmmph
bcdemon is offline   Reply With Quote
Old 04-27-2012, 10:17 AM   #6
Tom Struble's Avatar
Rewards Points: 2,002
yea.. all you gotta do is put in 8 screws
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
seeyou (04-28-2012)
Old 04-27-2012, 10:31 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
and a dab of caulk....
The Following User Says Thank You to Windows on Wash For This Useful Post:
seeyou (04-28-2012)
Old 04-27-2012, 10:41 AM   #8
Rewards Points: 27
Is not only about 8 screws. Roof company wants to replace flashings too, not the lid only. They gonna need to take off shingles around light. Thats what they wrote on estimate:"replace two curb mount skylights with two new fixed 22x46" wasco self flashing skylights cut down curbs to receive same. No interior sheetrock finishing include sheetrock end cap" Is it makes sence?
Old 04-27-2012, 11:17 AM   #9
Rewards Points: 27
W
Pics would help
Pics
went on the roof 2 days ago. Looks like gasket coming out, between glass and lid frame. I did put some roof cement (not sure if thatís the right product for that spot). We had some rain yesterday, is not leaking so far. But its only temporary fix I guess. Two years ago I took the lid off, and insulate gaps between sheetrock and frame, because cold air was coming in from attic in to the room. Itís much better now. Also shaft itself needs better insulation from attic. But its very limited space there (cathedral ceiling), not sure how to get there.
Old 04-27-2012, 12:21 PM   #10
+have insurance and workmans comp,cleanup and remove debris and hopefully guarantee their work and pay the help decently
seeyou (04-28-2012)
Old 04-28-2012, 08:06 AM   #11
Rewards Points: 83
If you're replacing just the skylight, then yeah that and some sealant.
I don't know about that skylight with a condom on it, never even heard of Wasco up here before. The install looks simple enough, tuck and fold here, nail there, all good.....
I think I would prefer a regular curb mount with front and back pans and step flash up the sides, counter flash to cover all that. A line of sealant around the top, drop the skylight on and guess what's last Tom, 8 screws...
Old 04-28-2012, 08:21 AM   #12
so..your saying what exactly?
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 05:46 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 03:24 AM
adding skylights to vaulted ceiling capslock Building & Construction 28 01-20-2010 09:24 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
Are roof skylights leaking? Halron Roofing/Siding 3 04-15-2007 03:06 PM
