#1 |
skylights
Can you install sky lights on a metal roof?
#2 |
skylights
Yes, far more prone to leak if not done right but it can be done with the proper hardware and flashing.
#3 |
skylights
thanks
#4 |
Metal Roofing
skylights
I would go with a curb mounted skylight for a metal roof. I see far too many remodels where the GC and customer order deck mounts or self flashing types. They are doable but, the curb mounts are the way to go because your bending your roofing up to a wood curb with no flashing kit to get in your way.
What type of roof do you have ? For example, the velux flashing kits do not work well with stone coated metal roofs, we usually fabricate out own from metal. The alum type velux kits are of a fixed size. We prefer to send sheet stock to the job and break it to the size needed. Last edited by AndyWRS; 02-02-2013 at 11:20 PM. |
#5 |
skylights
it is not stone coated. It is just a metal corregated (probably not the right term) roof that you normally see on out buildings not usually homes.
#6 |
Pro Slate Roofer
skylights
Buy 2 sheets of lead for each one. That will conform to the panels as you fabricate what you need.
Frank To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| New Roof and Skylights | JRMN | Roofing/Siding | 12 | 10-13-2011 08:29 AM |
| adding skylights to vaulted ceiling | capslock | Building & Construction | 28 | 01-20-2010 09:24 PM |
| condensation on skylights | JimNW | Roofing/Siding | 4 | 01-15-2010 09:27 PM |
| Attic fan and skylights on same circuit ok? | shadango | Electrical | 7 | 06-09-2008 03:50 PM |
| Are roof skylights leaking? | Halron | Roofing/Siding | 3 | 04-15-2007 03:06 PM |
