Just bought a 20 yr old house. Found the skylight forms so much condensation on cold nights that it drips on to floor. Its in the bathroom and I can't shower in that room. I would just like to get rid of the skylight and close it up. There is about 3 ft of sheet rock tunnel from the skylight to the room ceiling. So how do I go about this?
Thank you for your welcome and ideas. I will try the plexiglass until the weather gets warmer and the skylight/roof can be worked on. I will also be more specific. I was thinking of how to do the job but needed feedback if it was correct or if I was missing something. I would remove the sheetrock from the light tunnel, add the additional framing, then sheetrock the ceiling from below. Then on the roof remove the skylight and insulate then the patch roof. I though to insulate once the ceiling was patched so to hold up the insulation. Does this sound like a good method?
There is a vent fan in the bathroom on the ceiling next to the tunnel opening. But how long does one run the fan for ambient warm air on cold night? There is condensation build up. So how do you stop the consationsation build up on a skylight.
Dealing with skylights for years, its one of 2 things! The light is either aged and need replaced with better double glass or you have insulation problems! I would decide if you want to keep your light, and if you do, compare the price buying a new one compared to tearing out and filling it back in. I really think its just aged or has a bad seal where it sits on the curb! Skylights are nice to have and would hate to see ya lose it!
Yes I have to agree the skylight appears to be the origional from when the house was built 20 years ago and is aged. My husband is not comfortable with patching the roof with new shingles. The roof wa just replaced this past august...before we bought the house. Im hoping we can just close up the skylight as I believe this is the better way to go.
You must make the final decision on that----Skylight are used successfully in baths--but they must be done as a system---well made light----well insulated tunnel--proper ventilation.
If you feel that that will not be an option in your home then close the opening while those shingles are new enough to be patched in----best of luck---Mike----
If you replace the existing skylight as a good one made by Veluxe I'm sure your problem will go away. It's certainly a cheaper solution than getting rid of the entire skylight and in the long run will add value to your home.
I had the roof replaced this summer and also the 4 acrylic "skylights" with Veluxe units.No more sweating,more light,bath is warmer.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
