Skylight Vs. Tube - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-07-2012, 01:17 PM   #1
skylight vs. tube
getting a skylight replaced in one part of the house and considering putting in a few tube skylights in another part.
From a lighting standpoint, approx how many tubes give off light equivalent to 1 skylight... does it take 2 tubes, 4 tubes?
Everyone says the tubes magnify the light.. i can see how they reflect it down.. and I'm not physicist but it doesn't seem like you can actually increase the light coming out vs. what is going in.
casey
caseynshan is offline   Reply With Quote
Old 04-07-2012, 01:45 PM   #2
Rewards Points: 2,240
Depends on the size of the skylight vs. the size of the "tube-light".
Skylight size - 1 ft. by 1 ft. or 4 ft. by 4 ft.?
The "Sun-Tubes" work very well!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-07-2012, 05:08 PM   #3
Say 4x2 vs 1x1.
Assuming light even, it would take 8.
However skylight does have white walls which reflect less... but the light usually bounces once instead of 10 times.
People keep saying that the light in increased via the tube (which i don't buy)
If true then it might only take 2
However, Assuming a 5% loss in light on each reflection in the tube. On a 10 foot tube, unless the sun is perfectly lined up, you are going to be reflecting a bunch of times.. so then you would lose light and so it would take 10 or 20 tubes to be equal.
Decommissioning Knob and Tube Perry401 Electrical 7 05-14-2014 10:04 PM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Dome skylight leaking AAK Roofing/Siding 1 10-08-2010 05:47 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 07:23 AM
Water tube to fridge... Wolf_22 Appliances 9 04-04-2008 12:36 PM
