Skylight Leaks - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-07-2009, 11:46 AM   #1
skylight leaks
I had skylights(Kenergy) installed in 1993. they are now leaking. Even though the contractor has a lifetime warranty on leaks he says its not valid because the skylight seal is defective. Is there any recourse? also, the skylight company is out of business. Original contractor says I need all skylights replaced. does this seem correct?
leighlucy is offline   Reply With Quote
Old 10-07-2009, 11:50 AM   #2
skylight leaks
If the skylight company is out of business then any warranty with them is no longer valid
I imagine the contracor warrantied the installation against leaks - not the actual skylight
Without seeing pics hard to say - a fix might be some sort of caulking or sealant
But that may only be a temp fix due to the Temperature differences
Old 10-07-2009, 11:54 AM   #3
Commercial Roofing
AaronB's Avatar
skylight leaks
Yes, pics would be great, and if the skylight is able to be disassembled in order to replace the seal, you may be in luck.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Skylight on a flat roof? mchardo Roofing/Siding 6 02-19-2009 10:12 AM
Help! Our skylight is leaking and the sky is falling! Puzzledone Roofing/Siding 14 06-08-2008 08:10 PM
Leak inside a skylight apt94jesse Roofing/Siding 2 09-23-2007 07:00 PM
New vented skylight in existing roof lightninrodman Remodeling 1 07-26-2007 07:47 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
