Skylight Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-30-2014, 11:42 AM   #1
Skylight leak
Hi all,
Bought a house in November and this just yesterday during the first spring rain a leak formed. It's a velum skylight, on a relatively flat "rolled roof" section. I know this topic has probably been addressed a hundred times. I have a voicemail into the roofer that installed it about 6 years ago per the old home owners. I'm hoping he calls back. Any idea on what this could be / cost to repair?
Gutch92 is offline   Reply With Quote
Old 03-30-2014, 11:45 AM   #2
Doing This Way Too Long
Rewards Points: 532
Originally Posted by Gutch92 View Post
Hi all,
It's a roof leak and...
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
Old 03-30-2014, 11:47 AM   #3
Rewards Points: 532
Seriously though. On a flat roof it could be a few things but there is no way of diagnosing that over the internet from a picture of a wet ceiling.
Old 03-30-2014, 06:41 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
You are stealing my funny O&B.
Old 03-30-2014, 07:04 PM   #5
Rewards Points: 13,256
Useless showing picture of the inside showing the damage it's done.
Need pictures of the outside how it was done.
Rolled roofing, sky light, sounds like a perfect way to have a leak.
Old 03-30-2014, 07:32 PM   #6
Metal Roofing
Rewards Points: 600
I agree, we need to see some pics.
Could be as simple as a cracked skylight.
AndyWRS is offline   Reply With Quote
Old 03-30-2014, 07:53 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
The most common problems I have heard....people take a shortcut and don't use the flashing kit that Velux makes for the skylight. They don't want to spend the extra $60.
We are going to need to know if it was deck or curb mounted....pics will tell us.
Pics from the roof.
The Following User Says Thank You to ddawg16 For This Useful Post:
roofermann (03-31-2014)
Old 03-30-2014, 11:10 PM   #8
Rewards Points: 392
Pretty sure Velux requires minimum 3:12 roof pitch for installation. If you don't have the required pitch it'll require a curb. It's not going to be a cheap fix to do it right.
rustyjames is offline   Reply With Quote
Old 03-31-2014, 11:03 AM   #9
Rewards Points: 144
Concrete will crack.It's just a matter of where and when and skylights will leak it's just a matter of where and when.Ecpecially on a low pitched roof.
mako1 is offline   Reply With Quote
Old 03-31-2014, 12:37 PM   #10
Low Slope Roofing
Rewards Points: 114
I'll 5th that we need some pictures of the roof side of the skylight, all the way around and a over all shot.
Curb mounted skylights don't have a flashing kit like the deck Mounted ones. You basically get a skylight frame, you build a curb, flash the curb (that's the part the will leak) and counter flash.
If the roofer who installed it put a deck mount style on a flat roof I certainly wouldn't be inviting him on my property to have another go at it.
As far as pricing. It could be anywhere from $200 for a simple corner detail on a EPDM to 5-7K for a new skylight curb proper tie in to the existing roof and flashings.
Get a good picture of the actual roof while your up there also. Rolled roofing means one thing to home owners and another to a roofer.
1985gt is offline   Reply With Quote
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 09:47 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 08:46 PM
Skylight causing leak?? need2speed75 Roofing/Siding 11 10-05-2012 08:22 AM
Skylight in reroof - leak Achilleus Roofing/Siding 4 09-05-2011 10:27 PM
Leak inside a skylight apt94jesse Roofing/Siding 2 09-23-2007 07:00 PM
