Skylight Heat! HeatBlocker? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-12-2010, 02:41 PM   #1
We purchased a home 3 years ago. The past owner had 2 Velux skylights installed in our living room. My wife loves the natural light but the heat kills me. Do you have any suggestions on how to diffuse the heat? I know blinds may work, but do you know of any other method? I have been looking up the product called HeatBlocker. It is a canvas type of material that you install outside on the roof over the skylight. It suppose to diffuse 80% of the heat? Has anyone ever used this before? I live in Wisconsin and we have the extremes of hot and cold with snow.
Thanks in advance for your suggestions!
laplow is offline   Reply With Quote
Old 08-12-2010, 05:14 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
One option is to install a glass sash at the ceiling level. It should be openable (hinged) to access the space inside for cleaning. I've seen this done in bathrooms to reduce condensation problems in cold weather.
seeyou is offline   Reply With Quote
Old 08-12-2010, 05:35 PM   #3
Residential Roofer
Slyfox's Avatar
I have installed blinds a couple dozen times for home owners and all were happy with the results.
With the blinds you can leave them open in colder temps to get the suns heat, than closed when warming.
The last ones I did were Velux, the set up 'material wise' was roughly $68.00 per 2' x 6' unit, smaller units will be a few bucks cheaper and they are a reasonably easy diy project.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 08-13-2010, 03:20 PM   #4
Where did you purchase the Velux blinds? I have roughly 2x4 skylight and the cheapest I can find is $150.
Old 08-13-2010, 04:43 PM   #5
Somebody may make a flexible sheet that reflects visible light/infrared light that sticks on the outside of the skylight glass.
The radiant energy of sunlight only causes heat when it is absorbed.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Reducing Skylight Heat Loss? longshanks Roofing/Siding 26 12-04-2009 01:37 PM
