Skylight - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-31-2008, 08:38 PM   #1
skylight
Hi all!!
I have a corrugated metal roof on my home and want to install a couple of skylights.
It is a low pitch, about 2/12 . How would I flash them and any recomended brands.
Thank you
caper52 is offline   Reply With Quote
Old 01-31-2008, 09:01 PM   #2
check with the skylight manufacturer's instructions. you may be required to install a curb. some skylights cannot be installed in low pitch roofs, others can. suggest you go to roofing or window supply and check out the differnt ones - they can give you the manufacturer's literature too, it should show the recommended curb, flashing, and all attachment details (if you don't follow their instructions they will not warranty the skylight). good luck.
nacko is offline   Reply With Quote
Old 02-01-2008, 03:26 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
check out Velux
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
when to replace a skylight & flashing question CindiChm Roofing/Siding 3 10-08-2007 09:18 AM
Leak inside a skylight apt94jesse Roofing/Siding 2 09-23-2007 06:00 PM
New vented skylight in existing roof lightninrodman Remodeling 1 07-26-2007 06:47 AM
Skylight Dilemma... sootybuttercup Building & Construction 4 08-09-2006 04:33 PM
Skylight leaking advice needed!Thanks Beeper29x Roofing/Siding 12 10-04-2005 08:53 PM
