Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 09-10-2010, 10:34 AM   #1
Sky Light condensation
This is a strange one, I had our sky light in for years, no issues or leaks, even after our new roof, it was fine, now that we put in a remote shade, I see a water line coming down from the sky light, is it possible since this SL is in a bathroom, that if we have the shade closed, moisture can build up on the glass, and run down the wall, its not enough to even drip on the floor, just a small water line mark I see on the wall under the light? weird? can't figure this out.
turbomangt is offline   Reply With Quote
Old 09-10-2010, 01:27 PM   #2
Shut in w/o Home
seeyou's Avatar
It is possible.
seeyou is offline   Reply With Quote
Old 09-10-2010, 11:52 PM   #3
Moderator
The moisture was there before, just didn't condense until you blocked the drying air flow with the shade.
Similar to a basement slab that was "dry" until a floor covering was installed that molded. Took away the drying air movement.
Gary
Clothes taking longer to dry?
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
