Old 04-30-2014, 10:59 AM   #1
Share |
Skirt boards
Our siding goes right down the ground level. When we install our fiber cement I know their needs to be 6" between the siding and grade.
If I install a 5/4 x 6" pvc trim board along the bottom, I would flash that using a drip cap.
However, I see that they have pre-made skirt boards that look like it's slanted at the top and has a "tongue" on it. So, does that mean I wouldn't use flashing or a starting strip for my fiber cement siding?
cibula11 is offline   Reply With Quote
Old 04-30-2014, 12:17 PM   #2
Skirt boards
Sure that's not drip cap moulding your looking at?
Just stick with aluminum Z moulding.
Do not install the siding tight to the Z moulding leave about 1/4" gap.
http://www.bing.com/images/search?q=...electedIndex=3
Z moulding runs up behind the wall to protect it.
http://www.bing.com/images/search?q=...electedIndex=6
Old 04-30-2014, 12:27 PM   #3
Skirt boards
Heres a picture of it halfway down the page. THere are quite a few others when I search "pvc skirt board"
http://www.menards.com/main/store/20...e_onepg_v2.pdf
Old 04-30-2014, 12:29 PM   #4
Skirt boards
Well my original plan was to take a 5/4 x 6" piece and install, then z moulding, then starter strip and then fiber board. Since I've come across this, I wonder if this would be better, since it eliminates the need for a starter strip, flashing and saves time since I wouldn't need to make the z flashing.
Old 04-30-2014, 12:57 PM   #5
Skirt boards
I'd never seen that before, looks like it should work.
Old 04-30-2014, 01:13 PM   #6
Skirt boards
Yeah now I'll see if anyone carries it in stock
Should I replace wall skirt when installing new retro treads on existing stairs hkeiner Carpentry 12 02-15-2013 07:21 PM
Best way to move fridge on masonite boards so I don't scratch new floor? Studly Flooring 2 11-26-2012 08:57 PM
gaps between solid treads & skirt boards shotdown Flooring 9 08-02-2009 10:43 AM
some questions on stair case skirt boarding (how to measure, cut, materials) dwichman Carpentry 2 04-06-2009 05:40 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
