Skipped Roof Nails - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-21-2012, 08:19 AM   #1
skipped roof nails
contractor was suppose to install 6 nails per Timberline shingle and put 5 in instead leaving a 16-21 inch gap between the 4-5 th nail on the entire roof. Self sealing tabs have sealed down. Is there anyway to add missing nails without destroying this new roof?:
moonraker1 is offline   Reply With Quote
Old 07-21-2012, 08:24 AM   #2
Rewards Points: 850
they can be popped up easy when there cool in the morning. if he refuses then tell him youll contact the registrar of contractors, that will wake him up.
hotrod351 is offline   Reply With Quote
Old 07-21-2012, 08:41 AM   #3
No the contractor tried that!!!!
I was right there bright and early with him 2-3 times with a territory manager from GAF. The contractor destroyed each shingle while trying to lift them and had to replace them. GAF tech support says no way to fix it without destoying to new roof!!!!
Old 07-21-2012, 06:24 PM   #4
kwikfishron's Avatar
Rewards Points: 172
You had plenty of replies on your other thread you posted under a slightly different name.
Did you ever come back and read them?
kwikfishron is online now   Reply With Quote
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
