#1 |
Single slope roof venting
How to calculate the amount of ehaust i need for a single sloped roof that is1/12, 36'x 38', 24" overhang with full vent soffit, low end proper vents to the high end which is 3' 2" above the ceiling insulation. Looking to put a verticle wall vent at the high end that is about 2" in height for the length of the 36' wall.
#2 |
Architectural Designer
A very nice venilation calculator: http://www.metalera.com/CalcAboveSheathing.aspx?id=2094
Life's too short...so enjoy it! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to AGWhitehouse For This Useful Post: | rossfingal (10-10-2011) |
#3 |
Moderator
That calculator wouldn't go below 3/12 for your 1/12 slope for me. The other one for ceiling attics (as in your case) would, though, the other link.
You don't mention if it has a vapor barrier on the ceiling or not. If not, figure 9 square inches for every lineal foot of soffit intake and the same for ridge exhaust vents. This gives you 1/150, 1/2 total for 1/300. Your 2" high sounds right, depends on the screening size, spacing of the wires for the NFVA- net free venting area: http://www.airvent.com/homeowner/pro...it-specs.shtml Be sure you are getting 9 NFVA at the soffits, some manufacturers of punched vinyl de-rate it correctly; http://files.buildsite.com/dbderived...rived92755.pdf I suggest 2-3" holes to maximize the intakes and exhaust because of the very low slope. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 |
2nd link has no data...
#5 |
Moderator
End of second paragraph in your link, "NFA Calculator", from here: http://www.metalera.com/CalcAboveSheathing.aspx?id=2094
OP, enter your square footage and lineal footage of soffit and ridge vent........ Gary
| Display Modes | |
| Need opinion on this roof | profenx | Roofing/Siding | 14 | 10-12-2010 01:56 AM |
| Low slope roof options... | Blackhawk15108 | Roofing/Siding | 4 | 06-08-2010 10:33 AM |
| roof venting cathedral ceiling | Pete H | Roofing/Siding | 16 | 09-29-2009 03:26 AM |
| Venting a shed roof with 2/12 slope | atulc | Roofing/Siding | 5 | 08-25-2006 08:28 AM |
