Simple Job - If There Is Such A Thing :) - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-29-2008, 04:13 PM   #1
Simple job - if there is such a thing :)
New here, a DIY looking for a bit of advice. Living in Southern Ca, no snow, and seldom rains.
In order to install a Patio Cover, I am creating a light structural addition to a small portion of my house. The support is created from 2"x10" that is 39"Deep x 12.5'Wide. It will be following the angle of my current roof which is a very low slope, but will not actually be a weather barrier to my house in any way.
I do want it weather proof, as the new Patio cover will be hanging off of it. I am looking for the simplest / non-expensive way to weather proof this slight addition.
Thanks in advance.
Regor
Regor is offline   Reply With Quote
Old 07-29-2008, 08:24 PM   #2
Doing This Way Too Long
Rewards Points: 532
Sorry, couldn't resist.
Still trying to picture exactly what you're planning without seeing pictures.
OldNBroken is offline   Reply With Quote
Old 07-29-2008, 09:29 PM   #3
sorry, was at work earlier. Not sure a pic will help as I haven't done the actual work yet, was in the planning/buying stage. But I will attempt to explain more with the attached pic.
You'll notice that there is an enclosed room ( California room ) hanging off the back end of my house. The Ca room does not follow the roof line of my house. We are making one big patio cover (wood and Suntuf - corrugated panels). With the Ca room hanging off at a different angle, I have no support for that portion of the new Patio.
I plan to tie into the existing house roof line and fascia, and create a support so that I can install one long big patio cover. So, in essence, from looking down on the roof, it will look like a box - appx 39" x 12.5", connected to the existing roof line.
Make any more sense? If not, I plan to build the support this weekend, and it will not be subject to any bad weather here in Ca.
BTW - the roof of this "box" will just be exterior plywood.
BTW #2 - the piece of wood sitting on top of the Ca room is just sitting there to allow me to take a measurement using my laser level. That is NOT my structure
Thx
Simple job - if there is such a thing :)-img00044.jpg
Old 08-02-2008, 07:01 PM   #4
For the most part, here's my structure that I am looking to roof. It ended up being 3' x 12.5'.
Looking for the simplest and most economical way to protect this piece of structure.
Thx
Simple job - if there is such a thing :)-img00045.jpg
Old 08-02-2008, 08:43 PM   #5
Rewards Points: 532
Thx
Old 08-03-2008, 06:27 AM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
bitmun rubber roofing glued down and coat it the same as the existing roof.
Old 08-08-2008, 03:40 PM   #7
Call your local single-ply roofer and tell him you want to buy a piece with whatever dimensions you have ... as well as glue. I would have sold it to you.
parkerfairfield is offline   Reply With Quote
simple deck roof crandan Roofing/Siding 4 07-24-2008 12:22 AM
Simple wall switch question LZCenter Electrical 8 06-30-2008 10:01 AM
Simple VFD for 300watt Induction motor CaseyJ Electrical 6 04-01-2008 05:30 PM
Basic Simple Plumbing Questions wesc Plumbing 5 03-26-2008 08:23 PM
Is there such a thing? wiscborn Plumbing 6 06-29-2007 02:19 PM
