Simple Deck Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2008, 08:23 AM   #1
simple deck roof
I want to put a simple flat shingle roof over an existing wood deck. The deck is 16 ft from the house. I can go about 10 ft 10 in up at the house to be under second floor windows. What is a minimum pitch that I can go with and spacing for supports that can make the 16 ft from the house and not be too low at the edge.
crandan is offline   Reply With Quote
Old 07-22-2008, 09:32 AM   #2
Most shingle manufacturers require a minimum of a 3/12 pitch and I repeat, that is the very "Minimum" standard.
That means 3 inches of rise vertically for every 12 inches of run horizontally.
Otherwise, a proper flat roofing specification should be chosen instead of shingles.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-22-2008, 09:17 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
best you`re gonna get is 2 on 12,going with an sbs granulated roof system will get you about a 15 year warranty if it`s done right
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 07-23-2008, 07:51 PM   #4
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Post some pictures but I agree with both above posters. If you do go with shingles you need to ice shield the whole roof substrate before installing the shingles but you will not have a manufacturer's guarantee and the shingles probably will degrade in 10-15 years.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-24-2008, 12:22 AM   #5
which is why the sbs system is better,note with 2 on 12 pitch,,3-tab style would be the better choice
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
