Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-16-2012, 11:11 PM   #1
silicone rake drip edge to shingles ?
Just had a new roof put on and noticed that the felt did not quite reach the drip edge on the rakes in a few areas.
Roofer said it was nothing to worry about.
The shingles overhang the rake drip edge about 1".
Would it be a good idea to run a bead of silicone under the shingles at the rake shingle/drip edge junction, or is that completely unnecessary ?
Arky
Arky217 is offline   Reply With Quote
Old 02-17-2012, 12:05 AM   #2
Not going to help but if it makes you feel better go ahead.
The paper should have gone over it as you know, we also lay shingles up the rake under the roof shingles for added protection.
Old 02-17-2012, 05:57 AM   #3
Pro Slate Roofer
tinner666's Avatar
NO.. Leave it alone.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Roofmaster417 (02-17-2012)
Old 02-17-2012, 09:43 AM   #4
MJW
Roof edge should go over the felt on the rakes.
Leave it alone. You hired a pro, so you shouldn't have to worry about anything.
MJW is offline   Reply With Quote
The Following User Says Thank You to MJW For This Useful Post:
ParagonEx (02-17-2012)
Old 02-17-2012, 10:10 AM   #5
Doing This Way Too Long
Third chorus of "Leave it alone"
OldNBroken is offline   Reply With Quote
Old 02-17-2012, 10:52 AM   #6
And another, leave it alone.
framer52 is offline   Reply With Quote
Old 02-17-2012, 08:11 PM   #7
RFN-4A-LVN
Roofmaster417's Avatar
I will add., the same.
Roofmaster417 is offline   Reply With Quote
Using vented drip edge (ever-flo inhaler)? philipluckey Roofing 6 02-04-2012 01:03 PM
Roofing Material History Roofmaster417 Roofing 4 09-08-2011 05:49 PM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing 9 09-04-2011 10:29 AM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 02:01 PM
Overhanging Drip Edge Columbus Roofing 11 03-29-2011 10:32 PM
