Siding Trim Pieces - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-15-2013, 07:50 PM   #1
Rewards Points: 396
siding trim pieces
Hi,
I was wondering when using fanfold insulation behind vinyl siding should put up the trim pieces and starter strip then install the fanfold around it and inside part of the corner and j channels?
detroittigerfan is offline   Reply With Quote
Old 10-15-2013, 08:12 PM   #2
Rewards Points: 14,278
Nope, install all the fan fold then the trim.
Why are you using fan fold?
Old 10-16-2013, 07:41 AM   #3
Rewards Points: 396
For just a small layer of r value and air barrier. When I install azec around the door will that crush the fanfold once the azec is screwed into place? Also do you wrap the fanfold around the corners?
Old 10-16-2013, 07:56 AM   #4
For what little R value you going to get and the added cost for the fan fold and tape to seal the joints, the extra time and labor involved, possibility of setting up a double vapor barrier, I'd be going with house wrap instead.
Old 10-16-2013, 08:31 AM   #5
Rewards Points: 396
How do you consider fanfold a vapor barrier?
Painting James Hardie Siding and Trim RedAnt Painting 7 08-21-2013 04:36 PM
Drip cap placement with T1-11 siding? SMRcalidiv Windows and Doors 14 08-04-2013 11:39 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
