Siding For Shed... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-19-2017, 12:48 PM   #1
Rewards Points: 36
Siding for shed...
T1-11 plytanium, LP Smartside, or Truwood?
jamesgpobog is online now   Reply With Quote
Old 05-20-2017, 12:22 AM   #2
Rewards Points: 158
Re: Siding for shed...
Gold leaf.
You didn't say what your budget is, what your climate is, what your skills are, what style your house is, or really anything about your shed. So, yeah...I'm going with the suggestion of gold leaf for your exterior. It'll look much better than any of the options you mentioned.
NotyeruncleBob is offline   Reply With Quote
Old 05-20-2017, 04:46 AM   #3
Rewards Points: 2,396
Nah: too thin, besides it'll get stolen.
Aluminum foil is cheaper and polishes well.
As pointed out , we need to know more.
ED
de-nagorg is online now   Reply With Quote
Old 05-20-2017, 06:43 AM   #4
craig11152's Avatar
Rewards Points: 298
I have T1-11 on my shed in Michigan. It has held up well for several years.
Basically the question comes down to plywood vs engineered wood. The engineered wood industry certainly suffered from some wide spread failure and class action lawsuits in the past. Supposedly they have overcome those issues with the modern day products.
Don't look at me. I didn't vote for either one of them.
craig11152 is online now   Reply With Quote
Old 05-20-2017, 07:12 AM   #5
Rewards Points: 680
Vinyl
BIG Johnson is offline   Reply With Quote
Old 05-20-2017, 07:22 AM   #6
Rewards Points: 680
What could they do different? Hardboard is hardboard. Maybe a better layer of primer but that practically rubs off on your hands.
Most sheds I see have the T1-11 or something similar, like the 4" version.
Old 05-20-2017, 08:24 AM   #7
Rewards Points: 36
The shed is 96 sq ft. Imagine an 8x8 butted up to a 4x8, "L" shaped. Back wall (facing property line concrete block) is 16ft long. Roof is 'shed' (skillion).
Location is SoCal (compared to the rest of the country, dry climate). I'd probably describe myself as an advanced beginner, with a talent/proclivity toward beat-to-fit. Budget is as low as possible, I'm a cheap SOB. Existing house is "california ranch", slab foundation, stucco walls, single story.
I am also working alone. When I get to a point where I need more hands, I'll probably go pick up a day laborer.
Old 05-20-2017, 08:41 AM   #8
Going to build, already built?
All are sufficient for your area, pick the one you like.
use adequate roofing to keep the occasional rain away.
I built 4, 30 years ago with cheap as I could get sheeting, then used U. S. STEEL siding to cover that, and asphalt shingles.
Still standing, dry no leaks.
one is 8X 16, rest are 8 X 10.
ED
Old 05-20-2017, 08:57 AM   #9
craig11152's Avatar
Rewards Points: 298
That is a fair question. Which is why I would lean toward T1-11 if it were me. I know what it takes to keep it holding up.
Old 05-20-2017, 09:58 AM   #10
Rewards Points: 36
ED
Here's status quo....
Old 05-20-2017, 10:49 AM   #11
Rewards Points: 680
ED
The used car lot of sheds.
I built a 12x16 last year but I think the perfect size would be either 11x18 or 10x20
Steel Siding vs Vinyl Siding ?after? Painting 4 04-24-2013 07:22 PM
Patio Cover and vinyl siding? r_halleman Building & Construction 7 03-30-2013 12:55 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
