Siding Replacememt - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-18-2013, 09:24 PM   #1
Siding replacememt
I have removed the old cedar vertical siding and have a question before going back with 105 lap siding. There is a layer of sheathing on top of the studs. Can I put the new siding on top of this sheathing or do I need to put a layer of vapor barrier on top of the sheathing before installing the siding? Will be sealing the new siding on all sides prior to installing with oil based primer.
geocheves is offline   Reply With Quote
Old 07-18-2013, 10:13 PM   #2
Rewards Points: 14,290
No vapor barrier, you need house wrap. Such as Tyvek.
No way would I willingly install 105, way to much mantaince for me.
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
