Siding Inside Addition - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-12-2014, 04:37 AM   #1
Siding inside addition
I have an addition that the previous owners added on, by them selves. The entire addition is crap. The one thing I want to start to fix is the fact that there is siding on the inside of the room. How can I remove that section of the siding and maintain what little seperation to the outside that I have?
newhomeowner13 is offline   Reply With Quote
Old 08-12-2014, 04:50 AM   #2
roofermann's Avatar
Rewards Points: 401
By removing it? Need a clearer description (pics too) of what you're wanting to do.
roofermann is offline   Reply With Quote
Old 08-12-2014, 05:04 AM   #3
siding
I might be over thinking this, but the siding is inside and outside. There is a wall and it was "sealed". I will try and get pictures when I get back home.
Old 08-12-2014, 05:42 AM   #4
Rewards Points: 14,292
Need to at least know what type siding it is, what was it installed over?
I've seen dozens of porches built this way by DIY's, makes no since but it is what it is.
How to do this right depends on what type siding you have and supplying some pictures.
Bet there's going to be some other issues at the top of the wall and how the roof was tied in to the main building.
Prep, repair cedar siding before restaining Clicchi Painting 0 09-10-2011 05:03 PM
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 04:13 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
