Siding Air Gap - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-17-2013, 09:07 AM   #1
Rewards Points: 396
siding air gap
When you have siding that requires an air space/drainage plane you do that by using furring strips, correct? When you do that your obviously increasing the wall depth so does a piece of flashing need to be installed against the wall first so that any water that might get behind can drain and also it would cover up the underside of the sheathing and furring strips?
detroittigerfan is offline   Reply With Quote
Old 09-17-2013, 10:19 AM   #2
Rewards Points: 13,220
http://drain-plane.com/product.aspx
Old 09-17-2013, 12:26 PM   #3
Rewards Points: 396
Originally Posted by joecaption View Post
If you have trim around a window or door do they get installed over the furring strips as well?
Old 09-17-2013, 03:09 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,052
fur out the window also then install new trim on top of that so your trim will protrude far enough out from the wall in order to have a proper edge to caulk to
regarding the window flashing.. install your furring strips at the bottom and sides of the window but before you install more vertical furring the window needs to be flashed now so its lapped under the house wrap,
ive seen siders install the flashing directly on top of the furring which does absolutley nothing to water proof the top of the window.. water will run down behind it
woodworkbykirk is offline   Reply With Quote
Old 09-17-2013, 06:19 PM   #5
Rewards Points: 396
fur out the window or the window trim?
Old 09-17-2013, 06:53 PM   #6
Rewards Points: 396
Also what about flashing under the furring and sheathing? Otherwise it would be exposed at the very bottom.
Old 09-17-2013, 09:58 PM   #7
install furring strips around the window so you can install trim on top of hte furring.. flashing the window first so the cap flashing is tucked under the house wrap.. then for overkil flash the trim as well..
depending on if your installing new windows or simply installing new siding around exisitn windows changes the prep
Old 09-18-2013, 08:11 AM   #8
Rewards Points: 396
What about flashing under the furring and sheathing at the bottoms of the walls? Otherwise it would be exposed at the very bottom.
Old 09-18-2013, 08:35 AM   #9
you dont need flashing at teh bottom of the walls. simply hang teh siding down 1" or so
Old 09-18-2013, 08:41 AM   #10
Rewards Points: 396
But then the sheathing, etc would be exposed then
Old 09-18-2013, 08:53 AM   #11
Rewards Points: 396
do you put the furring strips over or near the nailing flange so you can put the trim over it?
Old 09-18-2013, 12:41 PM   #12
Registered User
Rewards Points: 5,180
http://www.google.com/url?sa=t&rct=j...Br40fQ&cad=rja
http://www.buildingscience.com/docum...shing+end+dams
http://www.joneakes.com/jons-fixit-database/2062
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
woodworkbykirk (09-19-2013)
How to Nail New Siding Under Existing Siding Shuriko Building & Construction 25 05-21-2012 09:33 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
