Sidewall Shingles And Flashing Replacement. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-13-2010, 12:59 AM   #1
Rewards Points: 526
Sidewall shingles and flashing replacement.
Hello, I have been reading a little about how to replace the flashing pictured below. Info on retrofitting flashing is a little hard to come by, but from what I have been able to put together, I probably have to remove the bottom 2 or 3 rows of shingles, replace the flashing the then re-shingle. Is that right? Is this type of flashing typically nailed to the roof, or the sidewall, or both?
Also, the window is not flashed and I can actually see into the house between the sill and the roof. Any idea on how to seal or flash it properly? A similar window elsewhere on the house has a very thick bead of roofing caulk in the gap between the sill and the asphalt shingle. Is that kosher?
You guys here in the roofing forum have been incredibly helpful with my other questions. Thanks a lot for that.
Sidewall shingles and flashing replacement.-p1060067.jpg   Sidewall shingles and flashing replacement.-p1060068.jpg
Windows is offline   Reply With Quote
Old 09-13-2010, 09:47 AM   #2
Doing This Way Too Long
Rewards Points: 532
I take it by the board you have nailed through the existing shingles you are planning on re-roofing this?
If so, your bottom row of shingles is too close to the roofdeck anyways. Carefully sawcut them 1 1/2" up, a sharp chisel on the ends where the saw won't reach. Remove the old flashing. You can slip a new wall flashing behind it with the help of a gentle flatbar.
As far as the window goes, caulk by itself is never a good fix for anything. One solution is to take a piece of wall flashing, cut all but 3/4" or so off the top leg and bend it forward to a 45 or better. This creates a one-way "wedge" under the window. Done properly once it slides under there it will grab the sill and will be difficult to remove. Caulk in front of that if you like and run a shingle over all the wall flashing.
OldNBroken is offline   Reply With Quote
The Following 2 Users Say Thank You to OldNBroken For This Useful Post:
seeyou (09-13-2010), Windows (09-13-2010)
Old 09-13-2010, 12:53 PM   #3
Rewards Points: 526
Thanks for the reply. This is a much better plan than removing the cedar shingles. I am planning on re-roofing this little bump out. Two more quick things - when you say 'run a shingle over all the wall flashing', do you mean that when I am finished, the part of the wall flashing that extends on to the roof should reside between the actual roof shingles and a protective shingle that is on top of everything? For some reason I assumed that the flashing would remain on top. Secondly, how far should the flashing extend up the wall behind the sidewall shingles? Thanks again.
Old 09-13-2010, 03:15 PM   #4
Rewards Points: 532
Standard flashings are 4"x4".
You will get a hundred opinions on here as to how to finish the wall flashings. I always let the job dictate which way to go. I try to leave the flashing exposed as long as it has a nice, snug fit over the last run of shingles. That does not always happen and it may not happen in your case.
You have two options:
1. Face-nail the flashing over the top of your last run and caulk the nail heads or...
2. Cut the salvage off the last run of shingles and nail them over the flashing, caulking the nail heads. Neither option is 100% right, nor 100% wrong.
Exposed nails anywhere on a shingle roof is one of those gray areas where we don't like to do it, but sometimes it's the only option.
The Following User Says Thank You to OldNBroken For This Useful Post:
Old 09-13-2010, 04:38 PM   #5
Chicago, IL
Michael Thomas's Avatar
Try to find an area where these is a loose shingle and lift if far enough to see if there is a Water Resistant Barrier (WRB, given the age of the property it will likely be a impregnated paper or felt material if a WRB is present) behind the shingles. If so, the new flashing should be installed behind it - you may have to pull some nails to do so.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
Old 09-13-2010, 05:35 PM   #6
kwikfishron's Avatar
Rewards Points: 576
It would be pretty easy to R&R that little triangle of siding, there is not much there and it terminates into the corbel. Go easy and number the pieces. About 15 min. of work there. Then you can flash and re-felt the wall and know it‘s right.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (09-13-2010)
Old 09-13-2010, 09:01 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
15 min?....
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Gary in WA (09-13-2010), seeyou (09-14-2010)
Old 09-13-2010, 09:09 PM   #8
Rewards Points: 532
Better have plenty of replacements and fresh paint. Those shingles are a good 75 years old and guarantee half of them are going to split at the slightest disturbance.
seeyou (09-14-2010)
Old 09-13-2010, 11:42 PM   #9
Rewards Points: 526
Originally Posted by kwikfishron View Post
It would be pretty easy to R&R that little triangle of siding, there is not much there and it terminates into the corbel. Go easy and number the pieces. About 15 min. of work there. Then you can flash and re-felt the wall and know its right.
I considered this but as OldNBroken correctly surmised, the 84 year old cedar shingles are brittle. My last line of defense if things really go off the rails on this project will be to remove all the old cedar singles in that triangle and replace them with new ones. Let's hope it doesn't come to that.
Old 09-14-2010, 12:21 AM   #10
Rewards Points: 576
Originally Posted by tomstruble View Post
15 min?....
That’s to remove the shingles.
I guess you guys are older than I thought
The 15 min. doesn’t start till after you make it to the top of the ladder.
Brittle or not your last line of defense would be my first.
You can punch the old nails through.
Worst case, a bundle of sidewalls is $40. You could replace at few shingles and have shims for life.
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Gary in WA (09-15-2010), Tom Struble (09-14-2010)
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 07:01 AM
Flashing skylight curbs with architectual shingles PerpetuallyRepairing Roofing/Siding 3 05-30-2009 06:01 AM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 10:31 PM
Roof to Sidewall Flashing handyman923 Roofing/Siding 1 09-13-2006 04:02 PM
