Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-13-2012, 12:22 PM   #1
Question
Should we use Copper or Aluminum flashing to waterproof our terrace?
We are planing to convert a roof into a terrace in our brick house.
When the previous construction was done, the workers already installed steel beams, corregated steel and a drain for this future conversion project. So this job basically requires the current roof to be pulled off, waterproofing done and then concrete poured. Additionally, the current window will be converted into a door for terrace access.
This brings me to the question in hand. Since most of this future terrace is situated above our kitchen, we want to make sure that we do proper and long-lasting waterproofing. My research has led me that proper flashing needs to be done. The question is this: Should I use copper (more expensive) or aluminum should work just fine? Are there any other suggestions?
My main goal is that we want to use something that will last a long time. We plan to put tile as our walking surface of the terrace.
Thanks!!
mystiky is offline   Reply With Quote
Old 08-13-2012, 12:44 PM   #2
Post a picture.
Old 08-13-2012, 01:37 PM   #3
Originally Posted by joecaption View Post
Post a picture.
Here you go. As you can see, this will be attached between existing brick side and concrete.
Should we use Copper or Aluminum flashing to waterproof our terrace?-img_5277.jpg
Pool Panel: Aluminum vs. Copper bcobb Electrical 18 09-16-2010 02:00 PM
Aluminum nails for flashing Malcolm Roofing 2 06-18-2007 12:03 PM
Aluminum to Copper Leenders Electrical 4 08-21-2006 08:54 AM
copper verses aluminum for 50 amp circuit wiggs Electrical 7 04-15-2006 06:25 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
