Should I Cover Old Roof With New Rubber Or Rip Off Old First? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-27-2011, 07:04 PM   #1
should I cover old roof with new rubber or rip off old first?
My porch roof (1300S/F) is half rolled roofing and half tar and pebble that's been painted over. I bought the house this way and it leaks all over. Should I put insulation board and rubber roof over it or rip it all off first? I have no idea how many layers are on there now but it seems pretty solid when I walk around on it.
h82diet is offline   Reply With Quote
Old 10-28-2011, 08:52 PM   #2
If your gonna re-roof it anyway, I would definitely take it down to the wood, see if there's some damage that needs to be repaired and fix it right. It wont cost you a dime more, just a bit more labor.
crackdaddy is offline   Reply With Quote
The Following User Says Thank You to crackdaddy For This Useful Post:
h82diet (10-28-2011)
Old 10-28-2011, 09:25 PM   #3
You're right! I know there is one "soft" spot and I should really look at/fix it. Anyway, when I take it down I can blow some insulation into the part of the porch room that's over the kitchen.
Old 10-29-2011, 01:09 PM   #4
I am a flat roofer. I highly recommend using a thermoplastic membrane. Don't use rubber. Duro-Last makes an excellent product. Check it out online.
Justinzoila is offline   Reply With Quote
Which is better, .... Rubber or Shingle for Semi-Flat Roof? cosmos10 Roofing/Siding 1 02-21-2010 09:05 AM
portico rubber roof - vinyl post installation? Ed Salsbury Roofing/Siding 2 09-05-2009 09:38 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Rubber Roof over Ice & Water Shield PerpetuallyRepairing Roofing/Siding 23 01-08-2009 10:50 PM
