Should I Change This Vent To A Higher Chimney Style One? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-30-2009, 02:04 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Should I change this vent to a higher chimney style one?
My microwave hood vents through a pipe that goes through the attic and then comes out the roof on a small vent about half a foot high that is basically like a U duct pointing down. The problem is the snow pretty much covers the opening. I can still see the vent from outside but that's just because we don't have much snow this year.
Should I replace this to a higher one, maybe a chimeny vent? Should I also avoid using the fan this winter? There was mold damage on the drywall in the kitchen which had to be removed and replaced and I'm thinking it was maybe caused by this.
Old 12-30-2009, 03:12 PM   #2
Remodeling Contractor
In areas with a lot of snow the vent should be a minimum of 12"
Old 12-31-2009, 11:14 AM   #3
Dave The Roofer
Dave The Roofer's Avatar
Send a message via AIM to Dave The Roofer
Your chinmey should be 3' higher than you ridge
Your chimney should be higher than your ridge line, the vent stock should melt the snow automaticlly from the hot water from showers, and any water usage.
Dave The Roofer is offline   Reply With Quote
Old 12-31-2009, 01:28 PM   #4
Registered User
Rewards Points: 5,498
Being a microwave/range hood, any grease that doesn't get caught in the filter at the unit will be pushed through the ducting. With the ducting making the 180* turn above the roof, coupled with the major outdoor temperature change there, any warm moisture/grease will be deposited on the double elbow air restriction.
Be safe, Gary
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 09:05 AM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
To Vent or not to Vent, that is the question debster Roofing/Siding 5 08-10-2009 04:48 PM
Hip caps to ridge vent KEITHnhia Roofing/Siding 1 07-04-2009 01:17 PM
