Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-06-2009, 05:03 PM   #1
Default Shingling over ridge vent -details needed
I'm putting ridge vents on a long ridge that dives into the side of a higher perpendicular roof.
The manufacturers directions (actually every manufacturer of ridge vents I could find) gave very little info on how to best apply the shingle caps over the ridge vent in this situation. Most seem to indicate that the vent should be held back about a foot from where the ridge dives into the other roof.
If there was no ridge vent I would install the cap shingles from the far end of the ridge right up into the dive and let the shingles on the higher roof overlap the last cap shingle. In this case for the 1 ft section with no ridge vent I assume I would do basically the same. But if I just place the ridge vent over the last cap shingle (1 ft from the dive-in) won't water be directed under the vent? What is the correct detail for cap shingling this end of the ridge vent and the short part of the ridge with no vent?
Similar question: The other end of the ridge is a hip. Do I end the ridge vent 1 ft shy of the hip? When cap shingling do I run up over the end of the ridge vent (hiding the end of the ridge vent) or do I place the ridge vent over the last cap shingle (1 ft from the hip) and then restart cap shingles on top of the ridge vent so that the end of the ridge vent is exposed? If the latter do the cap shingles hand out over the end of the ridge vent or are they flush with the end?
Old 11-06-2009, 06:49 PM   #2
Pro Slate Roofer
http://www.albertsroofing.com/Ridge%20Vent%20Detail.htm
THough I closed the ridge at a perpendicular roof area, I ran the vent and cap there too.
[img width=640 /]http://www.rooferscoffeeshop.com/images/photo_albums/30/82/MVC-001F.JPG[/img]
The roof in the second link looks lumpy because I dutch-lapped the entire roof to give it a dimensional effect.
tinner666 is offline   Reply With Quote
Old 11-06-2009, 06:52 PM   #3
Pro Slate Roofer
vgjhyggjhghuhh Got it that time.
Old 11-06-2009, 07:07 PM   #4
So you ran the vent all the way to the higher roof (and to the gable end) rather than stop short? (but stopped the cut opening short)
And you do a gable end same as a hip?
Old 11-06-2009, 07:47 PM   #5
Pro Slate Roofer
You know, I can't remember last time I did a hip that got RV.
Yes. I stop cutting on the first rafter so both ends of the board are securely nailed. Same thing when butting into a gable wall or a chimney. The last foot of rv and cap are dressing. It looks really tacky stopping short and putting cap under it. Cap are meant to go on top.
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be calculating shingles. To calculate the number of bundles of shingles for a basic gable roof first we need to measure the length and the width of the rectangular areas that is adding... Read More »
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Hip caps to ridge vent KEITHnhia Roofing 1 07-04-2009 03:17 PM
Roofer Contract Questions & Installing of Cobra II Ridge Vents KDFreder Roofing 0 06-29-2009 02:55 PM
Cathedral ceilings--ridge vent needed, or not? Larenda Roofing 5 06-04-2009 10:32 PM
new roof, ridge vent was in est, but not installed... Zel1 Roofing 28 06-04-2009 10:20 PM
Ridge Vent on a Shed jokiddjr Roofing 5 03-14-2008 05:22 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
