Shingling Over Cedar Shakes - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-10-2012, 03:26 PM   #1
Shingling over cedar shakes
I live in Canada and have very old cedar shakes that are still in good condition. I have just removed 2 layers of ashpalt off of them and am wondering if I can sheath over the shakes and then install the new architecural shingles. And I will be putting a layer of weather protection and ice and water shields on as well. Can I do this and what are the ramifications of doing it.
Thank you to everyone who can help me out with this
doinitallmyself is offline   Reply With Quote
Old 06-10-2012, 07:10 PM   #2
kwikfishron's Avatar
Rewards Points: 356
I’m not sure why you’d think The Cedar is in good condition other than the fact that removing the two layers of asphalt on top of it was easy and stripping the layer of Cedar is more like work.
To answer your question…NO, do not sheath over the Cedar, tear it off and start clean.
kwikfishron is offline   Reply With Quote
Old 06-10-2012, 07:25 PM   #3
Registered User
Rewards Points: 5,466
Not recommended, #2: http://publicecodes.citation.com/ico...007_par002.htm
Check with your local AHJ.
Gary
Old 06-10-2012, 11:33 PM   #4
I know alittle about alot
JWilliams850's Avatar
yeah dont sheath over the shakes. tear them off and fresh.
JWilliams850 is offline   Reply With Quote
Old 06-11-2012, 06:23 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,020
Always start with a clean base.
Old 06-14-2012, 09:21 PM   #6
Rewards Points: 850
real bad idea. if there shakes and not cedar shingles then it wont be that bad to take them off. really if there cedar shingles you could plywood over them. i honestly cant think what it would hurt. i know tearing off old cedar shingles is a real nightmare but when its done its done.
hotrod351 is offline   Reply With Quote
Old 06-14-2012, 10:26 PM   #7
Registered User
You need to fire-stop any wood shingles before sheathing over it: http://publicecodes.citation.com/ico...007_par003.htm
Gary
Old 06-14-2012, 11:13 PM   #8
Rewards Points: 850
there you go. seems you can as long as you follow safety. bite the bullet and tear it off. youll only have to do it once.
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Celotex/Masonite behind Cedar Shakes shub Building & Construction 1 09-22-2011 07:01 PM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 07:51 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 05:22 PM
