Shingles Waving - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-01-2008, 04:36 PM   #1
Shingles waving
Problem again! Today, strong wind. I found several shingles on my roof are waving. wow, I am scared. 10 year old roof!!!! How could it be like this????What should I do? change entire roof? or it's repairable?
wind image is offline   Reply With Quote
Old 04-01-2008, 04:49 PM   #2
Ed....., Roof Boy....... Help.........
Old 04-01-2008, 07:34 PM   #3
A little impatient, aren't we?
I would be more concerned about the hump I see in the 2nd photo, unless that is an optical illusion. It looks like some decking is lifting up and pulling away from the rafters, horizontally.
It also could be a bump in the roof, if this was a sloppy re-roof job.
This is what you can do, but be safe up there, please.
The lifted tabs can be sealed down with quarter sized dollups of roofing cement that comes in caulking tubes. Wait for a warmer day, when the shingles are not stiff and would try to spring back into their present shape.
Excessive roof cement would void the warranty if you were the original purchaser, but that is not your circumstance.
Plastic roofing cements contain solvents in them to keep the product pliable until usage. The solvents flash out of the product and could permeate into the asphalt portions of the shingles and chemically disolve the shingles.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-01-2008, 08:14 PM   #4
haha, it looks terrible. You think it's not a big problem? so I can fix it myself? For the first pic, the shingles was waving with wind. and for the second pic, it seems the same, but not that seriouse.
bother you again : )
Old 04-01-2008, 09:24 PM   #5
No, not terribly serious. I would add a couple of nails by that radiused edge if you can gently lift up the succeeding tab enought to make sure the nail gets covered by it.
The worst that can happen, is that you will have a substantial shingle blow off and then turn in the claim to your HO insurance and get a new roof if enough of them get blown off.
I made the impatient comment, because you came back 13 minutes later still seeking an answer to the original question.
We also do sometimes actually have to go do some work, besides play on the computer all day. J/K
Ed
Old 04-02-2008, 02:32 PM   #6
hahahaha, thank you so much! always help me out!
Old 04-02-2008, 07:13 PM   #7
You need to have the loose shingle tabs sealed down before the tabs blow off at the very least. Call a reliable local roofing company to do a complete roof inspection.
Abraham Lincoln Roofing is offline   Reply With Quote
Old 04-02-2008, 09:41 PM   #8
Good to see you over her Abe. Your knowledge will come in handy plenty of times.
Ed
Old 04-04-2008, 10:17 PM   #9
the roofing god's Avatar
Send a message via MSN to the roofing god
strip that roof,and redo it with a contractor who knows where to put the nails,looks like a crappy install
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 04-05-2008, 06:57 AM   #10
Thank you guys so much! But I could not believe what was happened, the house is just 10 year old.
Old 04-05-2008, 07:51 PM   #11
unfortunately for you,that is all too often where the price difference from one "contractor" to another falls,quality of workmanship,no fault on you sir ,As I`m sure like most builders,yours goes with the cheapest price,and with his typical 1 year builder warranty.you won`t have a problem till his warranty is over,but when you get your bids from qualified contractors,look harder at the value than you do at the cost of installation,there may be other items needing attention that were poorly done as well---Actually Ed has written a rather good brief on these situations ,which he titled"But the other guy said" it`ll shed a little more light on this situation for you-best of luck to you!
Old 04-06-2008, 07:19 AM   #12
Thanks TRG.
I dug it up from an older post.
Ed
But All Of The Other Guys Said!!!!!
I hear this more often than you would believe. You know what the most frustrating thing about that phrase is?
In practically every single instance, the “Other Guys” either did not really know what they were talking about, or even worse, they knew the right thing to recommend, but took the “Low Road” and did not advise you, the Home Owner about the implications of not doing your roofing project precisely as the manufacturer specified.
You might think to yourselves; The “Other Guy” seemed like he knew what he was talking about though. Ed, what makes your opinion any better or more valid than his? Aren’t you both just out here to try to sell me a roof and make as much profit on the job as possible?
Here is what I say to that; There obviously is some truth to the fact that a reputable company serving this area for over 23 Years under the same name and ownership needs to remain profitable to remain in existence. Yes, I spend a great deal of time with every single Home Owner I make a detailed presentation to, so; Yes, I would like you to understand the value in a quality, properly done roofing system as compared to over 90 % of all roofs done, which do not even meet the “Minimum” standards and specifications.
Before I begin to ramble on endlessly, and bore you with any self promotion, you may feel concerned enough to read through the following short portions of just a few of the research links I have provided, so you could receive a totally unbiased, neutral and objective opinion on some of the subjects that seem to be in conflict from one contractor to another.
If your investment in the future of your home is important enough to you, please feel free to inquire with as much vigor and depth as possible to arrive at the safest conclusion.
The following resources are all referenced as to author and web-site URL links for further analysis if you so desire. If you would prefer this document to be e-mailed to your attention, so you do not have to type in and search for the web sites, please request an e-mail version and I will gladly comply.
When you get done reading through the information; Please ask yourself the following question:
Who was the one who really gave me all of the correct advice, details and specifications to ensure my new roof and theoretical warranty plus my homes interior were not being placed in jeopardy?
Was it Ed, from RWR Company?
Or, was it “the Other Guy”?
I hope you appreciate the following information. Happy Reading!
http://www.bobandrodman.com/roofing.html
This is one of the best articles I have ever read about roofing specs being followed and “How to choose a good roofer”.
But over the years I have learned to spot good roofers by asking a few questions and identifying a number of indicators that seem to reveal what they really know about their trade and what kind of job they are likely to do. What I am looking for are those rare individuals who take pride in their work. They keep up with advances in materials and techniques. They make it a point to take to take questions to manufacturer’s technical representatives. They’re responsive to the concerns of their customers. And they are glad to take as much time necessary to explain things clearly.
Roofing isn't rocket science. But the average homeowner is not really familiar with the ins and outs of roofing so they have little choice but to depend on whomever they choose to do the work. This is a trust professionals take seriously. It is not enough that they are concerned and personable – they must also have sufficient resources of experience and knowledge to insure that their professional obligation is discharged to the homeowner’s advantage. That's why professionals are easy to spot. If you feel educated, as well as comfortable after your visit with a roofer, and the other criteria outlined below are satisfied, then you are as assured as possible that your job will meet your expectations.
another excerpt: From GAF
It is estimated that 9 out of 10 homes in North America do not have proper attic ventilation.
another: From Alcoa
Experts say inadequate intake ventilation causes 95% of all ventilation problems and will typically void the shingle warranty.
another:
Calculating how much venting your attic needs is relatively simple.
All you need to know is the area of the attic floor. Include the garage, if you have one and the soffit overhang because heat gets trapped above them, too.
To properly ventilate an attic, two types of vents are needed. Intake vents, which are located at the down slope edge of the roof (a.k.a. eaves) and allow fresh air into the attic; and exhaust vents, which are located near or on the ridge line of the roof and allow air to leave the attic.
another:
IS VENTILATION REALLY THAT IMPORTANT?
Deck movement and deterioration are commonly the results of poor ventilation. In the summer, too much heat buildup due to a poorly ventilated "flat ceiling" attic can cause the shingles to deteriorate prematurely. In the winter, deck-related problems are often due to condensation forming on the deck underside, which is also a result of poor ventilation. It is important to understand that shingles failing before their time due to inadequate ventilation will not be protected by the manufacturer's warranty.
another:
While manufacturers warranties will vary in terms of what is and is not covered and for how long, most offer reasonable value and protection for the end user. However, it is important to realize that should the product be installed improperly, even the best warranties on the highest quality materials may be rendered void and useless. The manufacturer has a right to expect that their product is aligned, lapped and fastened to meet their minimum requirements, otherwise their product will not perform as designed and the warranty will become invalid.
another:
Roofing is number 1 Construction Defect.
Construction Defect Problem Areas: Cause & Effect.
Taking a forensic view, or a backward pass, through a statistically significant sampling of Construction Defects (CDs) in order to determine the root cause & effect, we have categorized the most prevalent CD’s into a Top 10 List as follows:
  • Roofing
  • Sheet Metal Flashings
I hope that I have not gone overboard with the information supplied. I am passionate about providing the absolute best roofing materials and the best service as possible. Therefore, even though this may seem mundane and obsessive over-kill to you right now, you can at least get a better sense of how I feel about doing your roof on your home, the Right Way. When your home is taken care of with such passion, you will be proud and glad you chose to do things the Right Way after all.
Respectfully,
Ed
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 05:53 AM
Ed? IKO shingles Tree Frog Roofer Roofing/Siding 6 03-11-2008 08:42 PM
Does GAF still make 40yr shingles? Marlin Roofing/Siding 8 10-07-2007 12:49 AM
Solar Shingles? CuCullin Roofing/Siding 2 09-21-2007 08:11 AM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 08:57 AM
