shingles Question
Are you by chance saying that your only planning on recovering a portion of the roof ?.,Ummm.,you should not do that.If your going to recover part of a section there is no proper way of sealing the last course on top.
If your not tearing the section off then recover the entire section.You cannot recover from the bottom about half way then decide thats enough.You need to start at the bottom and run the entire section to the peak.
Remove the ridge cap before you recover then install new ridge after the entire section is roofed.Never recover half way up.Recover the entire section or tear of the area that has the damage then just replace that area with new.
