-   -   shingles Question (http://www.diychatroom.com/f9/shingles-question-136228/)
mammaw810 03-06-2012 08:48 PM
shingles Question
I am putting on new shingles to ones that already exist. Only half of the roof side is bad. My question is when connecting them to the existing shingles is there something to put in between the new and the old, for instance some type of caulking or roofing material. I wasn't quite sure if I have to have anything when lifting up the old shingle and adding the new ones to that row. I hope I am explaining this correctly. Would appreciate your help if at all possible.
joecaption 03-06-2012 09:24 PM
Not a great plan, but it can be done.
No caulking needed, the paper gets folded over the top and the the shingles just get ran to the peak and the cap covers the top.
It would be far better to add a ridge cap while your up there.
Bet you also using 3 tab shingles to, right?
How bad were the old ones?
mammaw810 03-06-2012 11:49 PM
actually I am not going up that far with the shingles to the ridge cap. I am only going up about 5-6 rows, and working my way down to the spouting. a tree came down on the garage roof and it only messed up just a few rows. They are actually dimensional shingles and that is why I was wondering if I have to use anything to seal the row I am attaching the new shingles to. Just wasn't quite sure if I should use some type of seal there in that paticular row. Thanks again for your time.
Just Bill 03-07-2012 07:44 AM
I would tear off the damaged shingles and replace with new of the same type/color. They will not match exactly but may over time. Going over dimensional shingle is not a good idea, especially just a small area. It will look bad.
Roofmaster417 03-07-2012 06:41 PM
Are you by chance saying that your only planning on recovering a portion of the roof ?.,Ummm.,you should not do that.If your going to recover part of a section there is no proper way of sealing the last course on top.
If your not tearing the section off then recover the entire section.You cannot recover from the bottom about half way then decide thats enough.You need to start at the bottom and run the entire section to the peak.
Remove the ridge cap before you recover then install new ridge after the entire section is roofed.Never recover half way up.Recover the entire section or tear of the area that has the damage then just replace that area with new.
seeyou 03-08-2012 06:58 AM
If I understand your question correctly, you'll be slipping new shingles under existing, breaking the existing seal. If that's the case, then it depends on the shingle. Some have the seal strip on the top, some on the bottom. If your shingles have the seal strip on the top, then no sealant is required where you finish under the existing. If you started out installing the patch shingles over existing, you'd need to seal the 1st new course to the old. Reverse that if the seal strip is on the bottom of the shingles.
