Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-05-2012, 08:38 PM   #1
JOATMON
ddawg16's Avatar
Shingles Over Torch Down?
When a roofing guy does a modified torch down system....does he still put shingles on top of that?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-05-2012, 09:15 PM   #2
firehawkmph's Avatar
No. The modified is the roofing material. It is used for low pitch roofs where shingles would not work.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-05-2012, 09:21 PM   #3
JOATMON
ddawg16's Avatar
Thanks....just confirming.....after I wrote the post I realized that nailing on shingle through that nice new torched down roof would not be a good idea....
My
and
Old 11-07-2012, 01:37 AM   #4
Mike Hawkins
Is modified torch down also used for low pitched hog valleys, where the bottom point contains a valley flashing? And in this torch down case, the modified itself replaces the shingles plus valley flashing?
One roofer suggested that for reroof bid where the rest of my roof would have shingles.
Other roofers didn't suggest that, so they would still continue with shingles it appears.
daluu is offline   Reply With Quote
Old 11-07-2012, 09:02 AM   #5
Daluu,
not sure what you mean by a hog valley. Modified roofing is a material that comes in a roll and the torch heats up the backside to adhere it to the roof. I don't see any advantage to putting shingles in low pitch applications, in fact I see it as a leak waiting to happen. My younger brother is a commercial roofer, union actually, for the last 30 years. He has forgotten more than I know about the low pitch roofs. I will ask him and let you know what he says.
Mike Hawkins
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing 9 09-04-2011 10:29 AM
Help! -- what is causing these shingles to fail? imaginator Roofing 1 09-18-2010 07:29 PM
IKO Shingles - beware mtugrad1985 Roofing 7 02-10-2009 04:42 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing 4 12-17-2005 06:39 PM
