Shingles With Metal Plates Under Them Lifting? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-09-2010, 03:11 PM   #1
Shingles with Metal Plates Under Them Lifting?
I have no knowledge when it comes to roofing.
I have noticed that there are shingles where the roof meets the siding of the upper roof that have like these metal plates underneath them. These shingles seem to be lifting or curling...
Is this a problem and what the best way to fix it.
Here are some photos to better illustrate the problem.
Also, looks like I might have some rot there too, not sure. Will have to wait till spring to take the siding off and have a look.
Any help is much appreciated.
Cheers!
earthad1 is offline   Reply With Quote
Old 01-09-2010, 07:56 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That's ypur step-flashing. Roofer should have bent them backwards so they would lie flat. He didn't want to nail in the keyway, so he left the nails out.
I would pull the shingles, and re-step-flash with the proper bend and a wider piece so I could nail them properly if I had to do it.
tinner666 is offline   Reply With Quote
Old 01-09-2010, 08:00 PM   #3
Thanks tinner666
Sorry, I'm not sure I know what you mean by bending then backwards so they lie flat. Lie flat on the roof, or against the sidewall? Is a keyway the spaces you see between shingles? Are you supposed to put nails there?
Since it's in a dry area, do you think I can wait until the spring or am I just asking for trouble if I do that? Reason I ask is that I'm in Canada, and it's January
Is this something a typical DIY'er can do? or should I really consult a pro. I don't want to make things worse. How much would something like this cost on average?
Thanks so much for the help.
Cheers!
Old 01-10-2010, 01:20 PM   #4
Pro Slate Roofer
tinner666's Avatar
Wait until spring and get a pro.
Old 01-10-2010, 01:21 PM   #5
Pro Slate Roofer
tinner666's Avatar
Nails shouldn't be in keyways. By reverse bending, at a 90 transition, you only want the metal about 80 degrees so it can be pressed into place to conform tightly.
Old 01-12-2010, 12:22 PM   #6
MJW
Agreed....
Looks like the roof should be replaced anyhow pretty soon, along with the siding in that area. You can see how it's get discolored and possibly moldy. A qualified Roofer that knows anything about siding, should be able to fix it for you correctly. IMO, a good sider was once a roofer or still is a roofer.
MJW is offline   Reply With Quote
Old 01-14-2010, 08:59 AM   #7
Replaced? Do you mean just that section or the entire roof?
It was replaced in 2005. The rest of the shingles on the entire roof are nice and flat, no cracks or anything.
Old 01-14-2010, 10:17 AM   #8
MJW
The shingles look like they are starting to curl. What brand are they? If they look this rough in many places, I would start a warranty claim ASAP. 5 years is usually the limit for getting a decent warranty claim.
Hard to believe anyone was still putting 3 tabs on......
Old 01-14-2010, 10:55 AM   #9
They only look rough like this where the step flashing has been installed. The remainder of the roof is nice and flat.
I don't know what brand they are and I don't know who installed them. The roof was replaced in 2005. I bought the house in the winter of 2006.
The inspector said they were good. Can I go after him? Probably not eh?
EDIT: Also, if you search my other threads, you'll see that I had attic issues that I fixed last winter... This might have started an premature wear on the shingles... But the attic is nice and dry now....
Old 01-14-2010, 11:05 AM   #10
MJW
LOL! Good one.......
I'm just telling you what I see in the pics. If I'm wrong, you will be fine. If I'm right, those shingles will show considerable wear in the next 5 years. I would get a qualified roofer to look at it. JMO
Old 01-14-2010, 11:15 AM   #11
I know...
I do a visual walk every spring since I bought the place... all except where the step flashing is installed it "looks" good. But yea, I will have a qualified roofer have a look when they replace that few row by the flashing... Same with that siding/plywood cuz I think there might be some rot.
Thanks man!
Old 01-14-2010, 03:18 PM   #12
Household Handyman
Rewards Points: 1,408
I've looked at those pictures, which I'm glad you provided, over and over and I have one question that I cannot figure out: It appears you have vinyl vented soffit's and the corner piece appears to be vinyl. But, are my eyes deceiving me (again) in that you have a "Hardie-Board" type siding which is placed into J-channel for vinyl siding there on the side of the dormer? I agree with the others that you have flashing which was installed wrong causing your shingles to stick up, but IF this is a masonite type siding and is placed into J-channel, that's the first I've ever seen it. Opinion here "tinner": Would this have been better with the long flashing which has the end under the shingles bent back at almost 90 degrees? Thanks, David
Old 01-14-2010, 08:52 PM   #13
Pro Slate Roofer
tinner666's Avatar
I'd have step-flashed the whole thing. At the top, if I couldn't work anything into place, I would have lenghtened a piece to cover my bets in case somebody ever washed the roof with hose.
Old 01-14-2010, 10:29 PM   #14
Registered User
Rewards Points: 5,216
I'd be a little worried about the water sign at the last piece of soffit near the barge/fascia board, on the right. Hopefully that was flashed correctly, though I can't see any diverter flashing extending down....
The soffit venting is an old style that clogs with dirt easily because the "holes" were punched with a machine. The newer ones have a circular hole, not slot that restricts the air flow when clean. Check from the attic side for light coming in the holes as a lot of times they just vinyled right over the existing small 6x16" cutouts every 8' into the boards, which isn't nearly enough.
Be safe, Gary
Old 01-15-2010, 09:46 AM   #15
Pro Slate Roofer
tinner666's Avatar
Be safe, Gary
I didn't catch that! Yes, that is troubling. There if supposed to be step flashing behind the fascia there and emptying out onto the roof like it does at that corner.
Metal over fiberglass shingles - steep slope napper Roofing/Siding 4 09-12-2008 11:20 AM
replacing metal back borch porch with shingles nurse47557 Roofing/Siding 1 05-22-2008 12:10 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
