Shingles For A Low Slope Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-16-2010, 08:12 PM   #1
shingles for a low slope roof
Hi all, need to replace a low slope roof (just < 2/12) with shingles. Different roofers...different suggestions...different quotes.
For sure an ice & water sheild on entire surface, but then what kind of shingle and what mfg ? For eg. BP will not warranty any shingle on < 2/12 slope - we wanted to use the Harmony 35 yr. Cannot see the roofline from the street so why not use a cheaper 3 tab. Just looking for the best application here. Appreciate your suggestions
wendl is offline   Reply With Quote
Old 09-16-2010, 10:59 PM   #2
From my experience its not going to really matter which one you are going to get. It comes down to the harshness of the sun and the quality of the job done by the roofer. If your roof comes into direct sunlight its going to breakdown much faster than one that is decently hidden from the sun. One side of my roof has a lot of direct sunlight and the asphalt is obliterated. On the other side there is little sun and the ashpalt is like in new condition. If the roofer does a lousy job then it doesn't matter which shingles you get again. I guess my best advice is go by referrals and other advice people give you.
Good luck.
gordon_roofer is offline   Reply With Quote
Old 09-17-2010, 07:14 AM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Modified bitumen would work better than shingles. you would not catch me putting shingles on less than a 3/12. Some manufacturers warrant it, I won't. After 10 years the shingles will be so beat up by snow and sitting water that you'll have to replace them. Put a low slope membranem like modified bitumen, epdm, pvc, tpo etc...
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
The Following User Says Thank You to Grumpy For This Useful Post:
federer (09-17-2010)
Old 09-17-2010, 08:49 AM   #4
Doing This Way Too Long
Rewards Points: 532
Nothing more to say...
OldNBroken is offline   Reply With Quote
Defective Atlas Shingles? 1 year old roof m&jinne Roofing/Siding 3 04-23-2010 02:41 PM
Should I replace my roof? skittlebear Roofing/Siding 8 04-10-2010 06:01 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Improperly installed roof ktpersh Roofing/Siding 1 05-15-2008 06:57 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
