Shingles On A Low Pitched Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-19-2009, 06:16 PM   #1
Shingles on a low pitched roof
Hello,
I'm beginning the process of planning for a new deck with a screened-in cover. Because of the way the house is built, I think the best roof will be a shed roof. However, the best pitch I could expect would be a rise of 3-5 inches over 12 feet. Is that too low for shingles? If so, will I be able to use metal instead?
I appreciate any help anyone can offer. Thanks.
oatlord is offline   Reply With Quote
Old 12-19-2009, 07:10 PM   #2
Chicago, IL
Michael Thomas's Avatar
That's a "flat" roof (below 2/12), and way too low for shingles as the primary weather barrier:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-19-2009, 07:51 PM   #3
firehawkmph's Avatar
Rewards Points: 1,884
Olord,
We never shingled anything below 4/12. Either used 90# rolled roofing, modified bitumen, or rubber. For the last two, make sure you have someone that is used to working with the materials.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Shingles on Low Pitched Roof? sandyman720 Roofing/Siding 2 08-01-2007 09:47 PM
