Shingles Buckling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-24-2011, 05:57 PM   #16
Rewards Points: 77
Originally Posted by GBR in WA View Post
Your 2" vents have 1.5" NFVA and the 4' with 2.75" NFVA should have 9"NFVA per foot on each soffit to vent 1/150; http://www.lomanco.com/ProductPAGES/CirkVents.html
The round vents should be touching each other or continuous for minimum vent supply; http://www.airvent.com/homeowner/pro...it-specs.shtml
The powered exhaust is pulling conditioned air from the house or crawlspace/basement.
Makes sence.
Based on what I have now, I come out with 90.25" NFVA and need 112" NFVA. So if I were to upgrade 15 of the 2" (22.5 " NFVA) to the continous, i'd be converting about 19', which would give me 239" NFVA.
Current calculations: 51 (2") x 1.5" NFVA + 5 (4") x 2.75" NFVA = 90.25" NFVA
Addition of some continuous: 36 (2") x 1.5" NFVA + 5 (4") x 2.75" NFVA + 19' (continuous) x 9" NFVA = 239" NFVA
Sound right?
daveplot is offline   Reply With Quote
Old 06-04-2011, 08:17 AM   #17
Rewards Points: 77
I began replacing two 8' sections of the round 2" screen vents with the Air Vent continuous vent, which Lowe's sells. I got up on the ladder and found that the screens were mostly clogged. So this could be the cause of the shingle issue.
Next weekend i'll work on the shingles and flashing on the chimney, and take photos and report back what I find.
Old 06-10-2011, 07:50 PM   #18
Looks like sheathing or possible tar paper problems. From those pictures it looks like either a DIY or bad workmanship job.
Roofster is offline   Reply With Quote
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 02:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 07:29 PM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 09:46 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 04:21 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 04:42 PM
