Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-01-2012, 05:35 PM   #1
shingles
how can you tell if a shingles is still good for use?
bmiuc is offline   Reply With Quote
Old 02-01-2012, 05:41 PM   #2
Rewards Points: 14,312
May want to tell us what your talking about.
Are there still in the package and you what to know if you can use them on your roof?
Open the package and see if there all stuck together, if they are there land fill.
Where where they stored?
Old 02-01-2012, 07:44 PM   #3
Gymschu's Avatar
Rewards Points: 1,032
As Joe said, could you provide more info. I guess a few clues would be: are they still in the protective plastic bundle? Have they been stored in away from the weather? If the bundle(s) are opened do they appear to have granules missing? How old are the bundles? I would think that if you ran across bundles from 1973, they may be degraded to some extent. Pics would help too.
Old 02-24-2012, 11:48 AM   #4
Stroudsburg Roofer
PAHome's Avatar
Shingles
shingles should be stored in away from the sun and in a flat area. If they are "glued together" like Joe said they are no longer any good.
www.pa-homeimprovements.com
"your local roofing experts"
570-484-ROOF
PAHome is offline   Reply With Quote
Old 02-24-2012, 06:53 PM   #5
DO IT RIGHT THE 1st TIME!
Give you an honest answer - If you only need a few shingles for a small repair a bundle doesnt cost much (usually less than $40). Unless its a discontinued color and you dont want a weird color spot post a picture of what you HAVE. If you can color match, buy a bundle. Its just easier and smarter that way in my opinion.
builttolast is offline   Reply With Quote
Old 02-25-2012, 09:01 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
570-484-ROOF
+1
Hopefully the supplier rotates his stock as well so you aren't getting a dinosaur.
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
New Shingles: Defective Shingles or Bad Install? TTZip Roofing/Siding 9 04-30-2013 01:03 AM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing/Siding 4 02-03-2010 03:21 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
